Finding kilograms of water on a spherical planet
To find the mass of water on a spherical planet, one should first calculate the total volume of the sphere using its average radius and the average depth of the oceans. The percentage of the surface covered by oceans is then applied to this volume to determine the volume of water. This volume is multiplied by the average density of water to find the mass in kilograms. Consistent unit usage is crucial throughout the calculations, and online conversion tools can assist with this. The final mass calculated was approximately 3.518x10^16 kg, though the accuracy of this figure was later questioned.
PAstudent
(Moderators note: moved from technical forums, does not use template)
How would someone approach this problem?
Find mass in kg of spherical planet if:
-71.11% of surface is covered by oceans
- avg depth of oceans is 12.83 furlongs
-avg density of water is 1.030 g/mL
-avg radius of planet is 4,895 miles
Do you have an average density for the non-water part of the planet? Or are you just looking for the mass of water on the spherical planet?
Edit: I see now in the title that you are just looking for the water.
Step 1, draw a picture.
Step 2, find the total volume of the sphere from avg. depth to avg. radius.
Step 3, multiply total volume by % surface that is water.
Step 4, multiply that volume by density to find mass.
Step 1.5: use consistent units in your calculations. :wink:
Likes RUber
When in doubt, google's unit conversion tool is very helpful.
Example:
"convert furlongs to km" returns.
1 furlong = 0.201168 kilometers.
I got 3.518x10^16 kg. Does that sound reasonable?
Edit: Disregard that I may have found an error in my calculations
