Finding length of an arc produced by projectile
The discussion revolves around deriving a formula for the arc length of a projectile's path, with the user expressing difficulty in calculus. They attempted to find y as a function of x and apply the arc length formula but ended up with a complicated result. Participants suggest that the arc length question is best framed as a math problem rather than a physics one. It is noted that while the arc length of a parabola can be complex, it is still solvable using the appropriate formula. The user is encouraged to share their work for more targeted assistance.
sk0071
So I decided to try deriving a general formula for fun. Being a high school student, the calculus got scary very fast. At this point, I'm just curious as to what the best approach to this might be. The approach I used was finding y as a function of x and then inputting it into the arc length formula. I eventually derived a very complicated formula that I think is wrong. I don't know very much about calculus as everything I've learned about it I've learned through the internet. Would this approach work? Is there a better way? If so what is the correct formula?
You should post what you've done as homework. It's not possible to help without seeing what you've done.
Arc length question is best posed as a math question - not physics.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 18 ·
