Finding Minimum from a completion of a square
  • Level: High School
  • Thread starter laker_gurl3
    Minimum Square
51 replies · 8K views · last reply
[tex]\sqrt 3 \sin 2t = a\sin 2t\cos \alpha[/tex]
is that the second equation?
the asin 2t and the sqrt 3 ?
Comparing the second terms would look like this:
[tex]\boxed{ - 3}\cos 2t = \boxed{a\sin \alpha }\cos 2t[/tex]
what happened to the [tex]\sqrt{3}[/tex] ? and how come its like that now?
Let's try again, we had:
[tex]\underbrace {\sqrt 3 }_A\underbrace {\sin 2t}_B\underbrace { - 3}_C\underbrace {\cos 2t}_D = \underbrace {a\cos \alpha }_{A'}\underbrace {\sin 2t}_{B'} + \underbrace {a\sin \alpha }_{C'}\underbrace {\cos 2t}_{D'}[/tex]
I named all the parts, A,B,C,D at the LHS and the same parts in the RHS with a '. It is clear that B = B' and that D = D'. Now if we let A = A' and C = C', we have what we want. Do you see that?
That would give the system of the following two equations:
[tex] \left\{ \begin{gathered}<br /> a\cos \alpha = \sqrt 3 \hfill \\<br /> a\sin \alpha = - 3 \hfill \\ <br /> \end{gathered} \right.[/tex]
yes i see that but what are we going to do with
[tex]\sqrt{3} = a\cos{\alpha} and -3 = a\sin{\alpha}[/tex]
what can you do with it?
Diving both equations would give [itex]\tan \alpha = - \sqrt 3[/itex] from which you can get alpha.
but if u divide them both it will be
[tex]a\tan{\alpha} = -\frac{\sqrt{3}}{3}[/tex]
The a will cancel out and what you wrote isn't correct. You either divide the first by the second and get [itex]\cot \alpha = - \sqrt 3 /3[/itex] or you divide the second by the first and you get what I had, which has the same solutions for alpha of course :smile:
so what is the final answer? [itex]\tan \alpha = - \sqrt 3[/itex]
and that's it?
what do you mean find alpha? didnt we just do that? is that -60 degrees or [tex]\frac{-\pi}{3}[/tex]
its just that i have no idea on what the final equation looks like both sides don't match at all right now, i have:
[tex]\sqrt{3}\sin{2t} - 3\cos{2t} = -\frac{\pi}{3}[/tex]
is that correct so far?
Yes, or 2pi/3. Now it's easy to find a using one of the two equations.
wait you said you can find A by using one of the two equations, you mean like this
[tex]a\sin{2pi/3} = -3[/tex]
i would get -3.464 now what do i do with that? can you just tell me the answer its been 7 hours already...
sin(2pi/3) = sqrt3/2, so a = -2sqrt3 when you use that angle alpha.
You can find another solution by using the other angle.
[tex]\tan \alpha = - \sqrt 3 \Leftrightarrow \alpha = - \pi /3 + 2k\pi \,\, \vee \,\, \alpha = 2\pi /3 + 2k\pi \Leftrightarrow \alpha = 2\pi /3 + k\pi[/tex]
...this is awsome almost 8 hours and still no answer
Perhaps you should re-read all of the posts and think carefully, all the necessary information has been said. If something is still unclear, be specific about what the problem actually is.
after all this 50 some post...look at the progression...
seems to me that this is gettin further away from the answer...
Seems to me that you have not carefully read everything which has been said. The -pi/3 was a solution for alpha, not for the RHS in general.
