Finding points where electric potential is 0
The discussion revolves around finding points on the x-axis where the electric potential is zero due to two point charges: a -10.1 nC charge and an +18.9 nC charge, which are positioned 13.8 cm apart. Participants are exploring the conditions under which the electric potential can equal zero and the implications of their calculations.
  • Participants discuss the setup of the problem, with one noting the need to find two points where the electric potential is zero. There is exploration of the potential contributions from both charges and consideration of distances relative to the charges. Some participants question the assumptions made about the locations of these points and the signs of the charges in their calculations.
The discussion is active, with participants sharing their attempts and reasoning. Some have successfully identified one point where the potential is zero but are struggling to find the second point. Guidance has been offered regarding the treatment of distances and charge signs, and there is acknowledgment of the challenges posed by the problem's setup.
Participants are working under the constraints of the problem as presented, with specific attention to the distances involved and the nature of the charges. There is mention of potential confusion arising from the units used in calculations.
natalie.*
Hi, this is my first time posting on the forums, so if I make any mistakes, I'm sorry.
This question has already been started here:
https://www.physicsforums.com/showthread.php?t=449070
but they never got to part (b).
PART A
A -10.1 nC point charge and a +18.9 nC point charge are 13.8 cm apart on the x-axis. What is the electric potential at the point on the x-axis where the electric field is zero?
I was able to figure this much out.
PART B
b) What is the magnitude of the electric field at the two points on the x-axis where the electric potential is zero? (Input your answers in order of increasing distance from the negative point charge)
[tex]q_{1}=-10.1 \times 10^{-9} C[/tex]
[tex]q_{2}=18.9 \times 10^{-9} C[/tex]
[tex]d=0.138 m[/tex]
[tex]r_{2}=d-r_{1}[/tex]
[tex]r_{1}=r_{1}[/tex]
[tex]V_{net}=\frac{Kq_{1}}{r_{1}}+\frac{Kq_{2}}{r_{2}}[/tex]
Simplified down to...
[tex]r_{1}=\frac{q_{1}d}{q_{1}-q_{2}}[/tex]
but this only finds me ONE point where the electric potential is zero. I'm supposed to end up with two...
I can't think of any other way to look at it, or get a quadratic out of it.
Where did I go wrong?
Consider the region of the line to the left of the negative charge. The potential due to proximity to the negative charge will be negative. The potential due to proximity to the positive charge will be positive. Now, the positive charge is larger than the negative charge, so you might expect there to be a distance to the left of the negative charge where the magnitudes of their influences will be equal.
Yeah, that makes sense to me, because that's how I worked out Part A, but I got the wrong answer for this.
If I work it out so that [tex]r_{1}[/tex] is to the left of [tex]q_{1}[/tex], then [tex]r_{2}=d+r_{1}[/tex].
If I simplify my formula out again, I just get the negative of my first answer, which to me just means my math is saying "You meant to go the other direction"...
If I work out:
[tex]V=\frac{Kq_{1}}{r_{1}}+\frac{Kq_{2}}{r_{2}}[/tex]
where I set [tex]r_{2}=d+r_{1}[/tex] (using the same positive value I found for [tex]r_{1}[/tex] originally), my electric potential doesn`t work out to be 0.
What is probably tripping you up is the mixing of assumed directions for radii, and charge signs in the formulae.
When I do these sorts of problems I find it easier to spot the locations where I can expect a zero by eye, then drop all the signs and constant and work with magnitudes in the regions of interest. So, for example, for your first point which you've already found, I'd go:
[tex]\frac{|q1|}{r} = \frac{|q2|}{d - r}}[/tex]
Why not give it a try for the point to the left of the negative charge?
Awesome, so I know what the two points are now, and I've double checked that the electric potential at both of those points is 0.
I'm still getting the wrong answer though, but I have a few more tries.
Since it asks for the magnitude of the electric field, I'm using:
[tex]E=|\frac{Kq_{1}}{r_{1}^{2}}+\frac{Kq_{2}}{r_{2}^{2}}|[/tex]
where [tex]K=8.99\times10^{9}[/tex]
and I'm leaving [tex]q_{1}[/tex] with it's negative charge for calculations (since the two charges would exert forces in opposite directions).
Is there anything wrong with that?
Your method looks good. Make sure that when you plug in your numbers for the calculation that you take into account that the units given for d are cm, not m.
The directions ended up throwing me off a little, but I finally got it with someone else's help. Thank you!
For anyone else:
Answer 1:
[tex]E_{1}=\frac{K|q_{1}|}{r_{1}^{2}}+\frac{K|q_{2}|}{(d-r_{1})^{2}}[/tex]
Answer 2:
[tex]E_{2}=\frac{K|q_{1}|}{r_{2}^{2}}-\frac{K|q_{2}|}{(d+r_{2})^{2}}[/tex]
Note that [tex]r_{2}>r_{1}[/tex], and they are distances from [tex]q_{1}[/tex], which is the negative charge.
I'm on this exact problem with different numbers and I'm fairly certain I've done one of the points right (the one to the left of the negative charge) but I can't figure out where the other point is. The math never gives room for a second point, and even when just looking at it there doesn't seem to be a logical second point of zero potential.
Is it at one of the charges? Is it at infinity? My numbers give me a point that's approx. 5cm to the left of q1 and then I'm stuck without a second point and I can't seem to figure out where it is from the replies already here.
I figured I'd just comment here so as to not rewrite out the question. Any help would be greatly appreciated.
Nevermind, I re-read the replies and I get it now.
