Finding potencial of forces - answer differs from solutions
The discussion focuses on discrepancies in potential energy calculations derived from force components, specifically comparing results with those from Kibble's "Classical Mechanics." The first force components yield different potential energy results, prompting a request for clarification on the mistakes made in the calculations. It is emphasized that the integral for potential energy should be calculated as V = -∫F⋅dr, and the importance of selecting a specific path for integration is highlighted. Additionally, the necessity of confirming that the forces are conservative before deriving the potential function is mentioned. The conversation underscores the need for careful consideration of the integration process and the path chosen.
Gabriel Henrique
3.1 (Kibble's Classical Mechanics) Find which of the following forces are conservative, and for those that
are find the corresponding potential energy function (a and b are constants)
Fx = ax + by², Fy = az + 2bxy, Fz = ay + bz²
Fr = 2ar sin θ sin ϕ, Fθ = ar cosθ sin ϕ, Fϕ = ar cosϕ
The first force components:
I calculated the integral V=-∫Fdr, using dr=(dx,dy,dz)
The result I found was
-(1/2(ax²)+2azy+2bxy²+1/3bz³)
The answer in the book (Kibble's Classical Mechanics): -(1/2(ax²)+azy+bxy²+1/3bz³)The second force:
I calculated the integral V=-∫Fdr, using dr=(dr,rdθ,rsinθdϕ)
-arsinθsinϕ(r+1)
The answer in the book (Kibble's Classical Mechanics): -ar²sinθsinϕ
Me and my colleagues can't find where we have mistaken. Can you help us? Our solutions are incorrect?
You probably mean V = -∫F⋅dr where the integrand is the scalar product of the vectors F and dr.
Kibble's answers are correct since they agree with F = - V. You didn't show any details of your calculation, so we can't tell you where you made your mistakes. Your approach should yield the correct answer. But this is not the only way to go.
For your method, note that the integral is along some path that connects your point of zero potential energy to the point where you are calculating V. It won't matter what particular path you choose, but you need to choose a path. (Pick a path that makes things easy!) When integrating along your path, be sure to think about what the values of x,y,z [or r, θ, φ] are along your particular path.
Edit: I assumed that you had already shown that the forces are conservative. If not, then you need to do that first as @kuruman points out in the next post.
Before you find the potential function, you need to establish that the forces can be derived from one. How did you do that? You can calculate a line integral for each force, but it doesn't mean anything if it is not path independent.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
