How to Find the Potential in Schrödinger's Equation?
  • Thread starter Thread starter gfd43tg
    Potential
gfd43tg
(a) Well, I just isolate A, so
$$A = \Psi (x,t) e^{a[(mx^{2}/ \hbar) + it]}$$
I am not sure if this is what is meant, seems too obvious.
(b) So I know the Schrödinger equation can be written
$$ i \hbar \frac {\partial \Psi}{ \partial t} = \Big [ - \frac {\hbar}{2m} \frac {\partial^{2}}{\partial x^{2}} + V \Big ] \Psi $$
So I take the given wave function,
$$\Psi = Ae^{-a[\frac {mx^{2}}{\hbar} + it]}$$
And find the derivatives with respect to x and t,
$$ \frac {\partial \Psi}{\partial t} = -A[a(\frac {mx^{2}}{\hbar}) + i]e^{-a[\frac {mx^{2}}{\hbar} + it]} $$
$$ \frac {\partial \Psi}{\partial x} = -A[a(\frac {2mx}{\hbar}) + it]e^{-a[\frac {mx^{2}}{\hbar} + it]} $$
$$ \frac {\partial^{2} \Psi}{\partial x^{2}} = A[a^{2}(\frac {4m^{2}x^{2}}{\hbar^{2}}) + i^{2}t^{2}]e^{-a[\frac {mx^{2}}{\hbar} + it]} $$
And I substitute back into the SE,
$$ i \hbar(-A[a(\frac {mx^{2}}{\hbar}) + i]e^{-a[\frac {mx^{2}}{\hbar} + it]}) = - \frac {\hbar^{2}}{2m} \Big( A[a^{2}(\frac {4m^{2}x^{2}}{\hbar^{2}}) + i^{2}t^{2}]e^{-a[\frac {mx^{2}}{\hbar} + it]} \Big ) + V( Ae^{-a[\frac {mx^{2}}{\hbar} + it]}) $$
From here I can isolate V
(a) No, this is not what is intended. You do not know the wave function up to the constant A so you obviously cannot have an expression for A involving the wave function. You need to apply some criteria that the wave function should fulfil. What such criteria do you know?
(b) Your post seems incomplete as it ends "So I". What did you intend to say?
Overall: Check your derivatives.
Re: Finding A. Remember what the wave function means. When you take psi* times psi, you get the probability of finding the particle in the range dx. So, what is the total probability of finding the particle somewhere? And so, how can you determine A?
For the rest: Can you see any factors to divide out of your last equation?
Also, the derivatives are not done correctly. Recheck what you have in the argument of the exponential.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
