The discussion revolves around selecting an appropriate resistor to use with a #47 incandescent lamp rated at 6.3V for 150 mA, in order to reduce the voltage from a 13.5V car battery to the required 6.3V across the bulb. Participants explore the implications of using different resistor values and their effects on voltage and current through the bulb.
- Homework-related
- Technical explanation
- Debate/contested
- One participant modeled the bulb as a resistor and calculated that a resistance of 42Ω would be needed to achieve 6.3V, leading to a theoretical requirement of 48Ω when considering the 13.5V source.
- Another participant confirmed that 48Ω is correct but questioned the practical application of using a 10% resistor, specifically the 47Ω resistor, which results in a voltage of 6.37V across the bulb.
- Some participants noted that the 47Ω resistor is close enough to the desired voltage, while others pointed out that the 56Ω resistor would result in a lower voltage of 5.79V, which is still workable.
- Concerns were raised about the current through the bulb with the 47Ω resistor exceeding the design rating, potentially causing it to burn slightly brighter, while the 56Ω resistor would reduce the current and dim the bulb slightly.
- One participant introduced the idea that variations in resistor values and potential voltage spikes from the car battery could lead to increased current and power dissipation, suggesting that a 56Ω resistor might provide better longevity for the bulb.
Participants generally agree that the 47Ω resistor is a practical choice, but there is disagreement regarding the implications of using it versus the 56Ω resistor, particularly concerning the bulb's brightness and lifespan. The discussion remains unresolved regarding the optimal resistor choice.
Participants noted that the design considerations depend on the tolerance of the resistors and the potential for voltage fluctuations in the car's electrical system, which could affect the current and power dissipation in the bulb.
