Finding stress and elongation in piston
4 replies · 2K views · last reply
nerdeagle24
Estimate the stress in the piston rod (6 cm in
diameter) [MPa] and the elongation of the 1 m long piston rod [cm] under these static
condition. Since these are external to the fraction, steel is often used, as in this case.
delta(l)=F*l/E*A
E for steel is 200 MPa
A=pi*r^2
I am really just totally stuck. I think you need to find force being applied onto the rod but I cannot figure that out
  • Sketch of a hydraulic ram: a piston of 40 cm diameter with water pressure of 1 MN/m² on the shaded left side, a piston rod of 6 cm diameter extending right with force P, and a 1 m length labelled.
What is the relationship between pressure, force and area?
Pressure =F/A
