Finding stress and elongation in piston
The discussion revolves around finding stress and elongation in a piston, focusing on the relationships between pressure, force, and area in the context of mechanics.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the relationship between pressure, force, and area, with some attempting to identify the force applied to the rod based on given parameters.
There is an ongoing exploration of the fundamental relationships involved, with participants reiterating the equation for pressure. Some guidance has been provided regarding the parameters available for solving the problem.
Participants express uncertainty about how to derive the force from the given pressure and area, indicating a need for further clarification on these concepts.
nerdeagle24
Estimate the stress in the piston rod (6 cm in
diameter) [MPa] and the elongation of the 1 m long piston rod [cm] under these static
condition. Since these are external to the fraction, steel is often used, as in this case.
delta(l)=F*l/E*A
E for steel is 200 MPa
A=pi*r^2
I am really just totally stuck. I think you need to find force being applied onto the rod but I cannot figure that out
What is the relationship between pressure, force and area?
Pressure = F/A
Pressure =F/A
nerdeagle24 said:
Pressure =F/A
Right, and you are given a pressure and an area.
  • · Replies 17 ·
