Finding the angle at which a box starts to slide down a ramp
The critical angle at which a box of mass 4.0 kg begins to slide down a ramp, given static and kinetic friction coefficients of 0.35 and 0.22 respectively, is determined using the equation θ = arctan(μ). The maximum angle before sliding occurs is calculated to be 20 degrees. The forces acting on the box include gravitational force and static friction, with the normal force expressed as mgcos(θ). The acceleration of the box is zero at the critical angle.
  • Understanding of static and kinetic friction coefficients
  • Basic knowledge of Newton's laws of motion
  • Familiarity with trigonometric functions, specifically sine and tangent
  • Ability to manipulate equations involving forces and angles
  • Study the derivation of the equation θ = arctan(μ) in physics
  • Learn about the differences between static and kinetic friction
  • Explore applications of Newton's laws in real-world scenarios
  • Investigate the effects of varying mass and friction coefficients on critical angles
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of friction and motion concepts.
joe426
A box of mass   4.0 kg is placed at rest on a ramp. The coefficients of static and kinetic
friction are $&  0.35 and $%  0.22, respectively. As the ramp is slowly raised from a
horizontal orientation, find the critical angle above which the box starts to slide.
ƩF=ma
I break ƩF=ma down to
F(gravity) x sin∅ - μ(kinetic) x F(normal) = ma
This is as far as I get before I start to get confused. In order to solve for ∅ I need to find accerlation, which i can't think to do without knowing the angle, and the normal force. I can see that the normal force is equal to mgcos∅.
Thanks for the help
Hello, joe426
joe426 said:
[ find the critical angle above which the box starts to slide.
Note that you are looking for the maximum angle before the block begins to slide. So, what would the acceleration be? Should the friction force in your equation be static or kinetic?
TSny said:
Hello, joe426
The acceleration would be 0.
The equation would then be
ƩFx = ma = 0
mgsinθ - μmg = 0
θ = sin^-1 (.35)
θ = 20 degrees
Thank you!
ƩFx = ma = 0
mgsinθ - μmg = 0
θ = sin^-1 (.35)
θ = 20 degrees
Yes, a = 0. But, earlier you stated that the normal force would be mgcos∅. Now you have it as just mg.
Which is correct?
Which is correct?
I think mgcosθ is correct but now I don't know how I would solve for theta.
mgsinθ - μsmgcosθ = 0
mg( sinθ - μcosθ) = 0
sinθ - μcosθ = 0
μ = sinθ/cosθ = tanθ
θ = arctan μ
  • · Replies 32 ·
