MHB Finding the Area of a shaded region (two shapes)
  • Thread starter Thread starter Coder74
    Area Shapes
To find the area of the shaded region formed by two shapes, the area of the circular sector is calculated and then the area of the isosceles triangle is subtracted. The formulas used are A_S = (1/2)r^2θ for the sector and A_T = (1/2)r^2sin(θ) for the triangle, with θ given as 150 degrees or 5/6π radians. After substituting the radius and angle values, the final shaded area is approximately 818.4 square inches. The calculations confirm the method is correct, leading to a clear understanding of how to approach similar problems involving multiple shapes.
Coder74
Hello,
I've done something similar to this before but this question is really different because it contains two shapes. Now I'm really confused and I really appreciate the help~! View attachment 6004
-Cheers
Mathematics news on Phys.org
I would take the area of the circular sector $A_S$ and subtract from that the area of the isosceles triangle $A_T$ to get the shaded area $A$:
$$A=A_S-A_T$$
where:
$$A_S=\frac{1}{2}r^2\theta$$ where $\theta$ is in radians.
$$A_T=\frac{1}{2}r^2\sin(\theta)$$
Can you proceed?
Thanks for the reply, Mark I really appreciate it!
However, I'm unfamiliar with " \theta " I haven't seen that before.
It is a Greek letter usually used to represent angles. In this problem, we have:
$$\theta=150^{\circ}=\frac{5}{6}\pi$$
Thanks again, Mark!
Triangle AT=193.21
Sphere AS=1,011.64
Shaded Area=818.43
This is what my final answers came up to be.
I get:
$$A=A_S-A_T=\frac{1}{2}r^2\theta-\frac{1}{2}r^2\sin(\theta)=\frac{1}{2}r^2\left(\theta-\sin(\theta)\right)$$
Now plug in the given values for $r$ and $\theta$:
$$A=\frac{1}{2}(27.8\text{ in})^2\left(\frac{5}{6}\pi-\frac{1}{2}\right)=\frac{1}{12}(27.8\text{ in})^2\left(5\pi-3\right)\approx818.4\text{ in}^2\quad\checkmark$$
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
