Finding the Coefficient of friction
The discussion centers on calculating the coefficient of friction for a 135 kg sled being pulled at a uniform speed with a rope tension of 119 N at an angle of 19.3 degrees. The correct formula for the coefficient of friction (μ) is derived from the relationship μ = Ff / Fn, where Ff is the frictional force and Fn is the normal force. The final correct calculation for μ is determined to be approximately 0.0874, after addressing a math error in the initial calculations. Participants confirmed the importance of using the correct components of forces in both x and y directions to arrive at the accurate solution.
  • Understanding of Newton's laws of motion
  • Knowledge of trigonometric functions and their applications in physics
  • Familiarity with the concepts of force, normal force, and friction
  • Ability to perform vector resolution of forces
  • Study the derivation of the coefficient of friction formula in detail
  • Learn about vector resolution techniques in physics
  • Explore examples of friction problems involving inclined planes and angles
  • Review the concepts of static vs. kinetic friction and their applications
High school physics students, educators teaching mechanics, and anyone interested in understanding the principles of friction and force analysis in real-world applications.
Nanart
A 135 kg sled is being pulled along a horizontal surface at a uniform speed by means of a rope making an angle of 19.3 degrees with the horiontal. If the tension in the rope is 119 N Find the Coefficient of friction.
u=Ff/Fn
I have never done a question like this before but i fugured i probably had to find the force from the horizontal..im not sure if i did it right but i used trig to find that force and i got 112.3 N i then put that in the formula U=112.3/135 and i got 0.8319 but I really have no idea if i did it right.
You are correct. \mu F=F_{f} so the ratio of the 2 must be the coefficient of friction. I also checked and our numbers match.
Awsome...Thanks
But don't forget that the weight of the block is not 135 N; its mass is 135 Kg. Also, the normal force fron the weight is offset by the upward component of the pulling force.
HI i don't really get how u get u=112.3/135
do you use the component method?
here are my calculations...please tell me if they are right
y components
Fnet=Tensiony +Fnormal - Forcegravity
0 =119*sin19.3 + Fnormal -135*9.8
Fnormal= 135*9.8 -119*sin19.3
=1362.33N
Ff=1362.33*u
x components
Fnet= Fappx-Ff
135*a=119cos19.3 - 1362.33
0=119Cos19.3 - 1362.33 (because constant velocity, so acceleration= 0)
U=119Cos19.3/1362.33
=0.0824
I am in grade 12 and I understand tht grade 12 and grade 11 methods are different, but please tell me what i did wrong and why i am not getting the right answer. THank you
y components
=1362.33N
Ff=1362.33*u
x components
Fnet= Fappx-Ff
=0.0824
You are on the right track i had my teacher explain it to me and the answer is actually 0.0874
y components
=1362.33Nyou made a simple math error here that carries through the rest of the problem[/color]
Ff=1362.33*u
x components
Fnet= Fappx-Ff
=0.0824
see note above on math error; otherwise your method is very good.
thanks guys...appreciate your help
  • · Replies 20 ·
