Finding the Distribution of Steps for Pairs Game with n Objects and m Values
  • Thread starter Thread starter LENIN
The discussion focuses on determining the distribution of steps in a game involving n objects and m values, where pairs of objects with equal values are randomized until no pairs remain. Participants clarify that a 'step' refers to each instance of randomizing a pair, not the overall process. Initial probabilities for the game ending in the first step are calculated, revealing non-monotonic behavior and suggesting that the probability distribution may follow a specific pattern. A conjectured general solution for the distribution is proposed, although it remains speculative and requires further validation. The conversation highlights the complexity of the problem, especially when considering different values of m and n.
LENIN
This question is part of a larger problem I'm working on, but it seams to be causing me the most problems. Any help or tip would be appreciated. So here it goes. We have n objects which can have any of the m allowed values. If we find a pair of objects with equal values, we change their values to new random values (from 1 tom m). We repeat this until there are no more pairs. What is the distribution of the number of steps this game can last.?
I did some numerical simulations but I would like to have an analytical solution. I only managed to get an analytical solution for the probability that the game ends in the first step. I also noticed that the probability has a peak close to the beginning (it's not monotonous as I first suspected).
So if we have for example
1 2 3 2 4 2
Would we first randomize the first occurrence of the 2's; and then if one of them again happens to form a pair, for example
1 5 3 2 4 2
we do it again.
If there are two pairs, for example
1 2 3 4 2 5 1
will we do them separately (first the 1's, then the 2's)? If so, and randomizing the 1's again produces a pair, do we first do the new pair or first the 2's (not sure if this matters).
Is a 'step' each time we randomize a pair, or each time we have to start over after randomizing all the initial pairs?
1 2 3 2 4 2
1 5 3 2 4 2
we do it again.
No, we choose which pair to randomize at random. And we repeat the proces until there are no more pairs.
1 2 3 4 2 5 1
Yes.
We allways choose pairs at random (if there are any ofcourse).
Each time we randomize a pair.
Well, for n = 2, we could have:
1 1
1 2
2 1
2 2
2 of these games last zero turns (already good).
so P(t = 0) = 1/2
Whichever of the two identical pairs we have, we
have a 1/2 chance of winning on the next turn. So,
for n = 2, we have
P(T = t) = (1/2)^(t+1)
For n = 3, we could have:
1 1 1
1 1 2
1 1 3
1 2 1
1 2 2
1 2 3
1 3 1
1 3 2
1 3 3
2 1 1
2 1 2
2 1 3
2 2 1
2 2 2
2 2 3
2 3 1
2 3 2
2 3 3
3 1 1
3 1 2
3 1 3
3 2 1
3 2 2
3 2 3
3 3 1
3 3 2
3 3 3
We see that exactly 6 of these are favorable immediately,
and so P(t = 0) = 6/27 = 2/9.
If we have one of the ones with all of them the
same, then the probability we win on the next turn
is 1/4, because we can pick one pair randomly in
4 ways, and only one will be favorable.
If we start with 2 of a kind and 1 off, then the
same is true: we can pick the pair to randomize in
one of 4 ways, 1 of which is favorable.
So...
P(T = 0) = 2/9
P(T = 1) = 7/9 * 1/4
P(T = 2) = 7/9 * 3/4 * 1/4
P(T = 3) = 7/9 * 3/4 * 3/4 * 1/4
P(T = t) = 7/9 3^(t-1) / 4^(t)
Just from the n=2 and n=3 cases, I can make a wild
guess that the general solution looks something
like...
P(T = t) = c (n-1)^(t-1) / n^t
for some c, which may vary a little bit.
Does that look about right, as far as fitting the curve goes?
DISCLAIMER: this is all wild and speculative conjecture.
Your 2 examples seam to work OK but the generalization doesn't. I will see if I can do something with it. There is also still the problem if m doesn't equal n. If m<n the solution is trivial (the game can not end).
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
