Finding The Divergence Of A Vector Field
The discussion focuses on finding the divergence of the vector field < ex2 - 2xy, sin(y^2), 3yz - 2x>. The correct method involves calculating the divergence using the formula ∇ dot F. The initial calculation yielded an incorrect result, with a discrepancy in the last term, where one participant obtained '3y' instead of the correct 'y' as indicated by Wolfram Alpha. The error was identified as neglecting to differentiate the term -2xy in the first component. The clarification led to agreement on the correct answer, emphasizing the importance of careful differentiation in vector calculus.
Baumer8993
Find The Divergence Of The Vector Field:
< ex2 -2xy, sin(y^2), 3yz-2x>
I know that divergence is ∇ dot F.
When I did it by hand I got
2xex2 + 2ycos(y2) + 3y
However wolfram alpha says it should be
2xex2 + 2ycos(y^2) + y
The difference is the last y. So who is right? This is for a divergence theorem problem, but I do not have an answer key.
When you worked out the first term, you forgot to differentiate the -2xy.
If you include this, your answer will agree with Wolfram.
Hi Baumer8993! :smile:
- 2xy ? :wink:
Oh wow, thank you for the help!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
