Finding the Flux of a Vector Field
The discussion revolves around finding the flux of a vector field defined as v → = a/(x^2 + y^2)z through specified rectangles in the xy-plane and yz-plane. Participants are exploring the mathematical formulation and integration techniques required for the problem.
  • Participants discuss the appropriate expressions for flux, questioning the use of Φ = E⋅A versus the integral form Φ = ∫E⋅dA. There are attempts to clarify the setup for double integrals and the implications of the vector field's behavior over the area.
Some participants have provided guidance on setting up integrals and interpreting the problem, while others are still seeking clarity on the requirements for both parts of the question. There is an ongoing exploration of how to approach the integration and the boundaries involved.
Participants note the need for clarity on whether both parts of the problem must be answered in integral form and express uncertainty about the boundaries for the integrals based on the problem's setup.
Civil_Disobedient
A vector field is pointed along the z-axis,
v → = a/(x^2 + y^2)z .
(a) Find the flux of the vector field
through a rectangle in the xy-plane between a < x < b and
c < y < d .
(b) Do the same through a rectangle in the
yz-plane between a < z < b and c < y < d . (Leave your
answer as an integral.)
Φ = EA
E
= F/q
The problem looks similar to this (I used an image of a similar example):
This example here had flux E0⋅A = E0ab
So for this problem, I tried doing the same thing but first finding electric field of vector v: E = F/q = a/(x^2 + y^2)z / q = aq / (x^2 + y^2)z
And then plugging into formula for Φ:
Φ = EA = aq / (x^2 + y^2)z ⋅ xy
I know I messed up somewhere, especially because the question asks to have an integral for an answer but I'm not sure which formula to use or how to use it.
The expression to use is not Φ = EA, because the field is not constant over the area. The integral to use is Φ = ∫E⋅dA. Because the field and the directed area are both along the z-axis, you can write Φ = ∫E dA =∫dx ∫ E dy. Do you know how to do double integrals?
I don't, haven't covered double integrals. Will I be able to do this without double integrals? How would I find electric field in this case? I know area of the rectangle is just length times width, within the x and y bounds. Would those be the bounds of the integral? But there are two sets of boundaries, one for x and one for y
Is that a unit vector z? And is it in the numerator?
Yes, and the z isn't in the numerator
Actually, I don’t know why I asked. It has to be in the numerator. I don’t even know what it would mean if it was in the denominator.
Imagine a small rectangle of area ##dA=dxdy## at some point ##(x,y)## and on the area. This rectangle is so small that you can write its contribution to the flux as the product of the field at that point times the small area ##d\Phi=E~dxdy##. In other words, you assume that the field is constant over the area if the area is small enough. Now consider a strip of length ##b## running parallel to the ##y##-axis which means that the value of ##x## is fixed at ##x##. To find the flux through it, you need to add continuously the contributions through all the small rectangles that make it up. You have$$d\Phi{(x)}=dx\int_0^b \frac{a}{x^2+y^2}dy$$The value of this integral is a function of ##x## multiplying ##dx## and represents the flux through the strip of length ##b##. To find the flux through the rectangle of of length ##b## and width ##a##, you need to add, also continuously, the contributions from all such strips that make up the rectangle.
$$\Phi=\int_0^a d\Phi{(x)}dx=\int_0^a\left (\int_0^b \frac{a}{x^2+y^2}dy \right)dx$$ Note that the term between parentheses is a function of ##x## only that you get by doing the integral between them. That, in a nutshell, is how you do a double integral. It's nothing mysterious, just two continuous additions instead of only one.
I fully agree.
I 'liked' the tutorial approach by @kuruman and won't retract that. However, it turns out this can be interpreted as giving the full answer -- depending on whether the
(Leave your answer as an integral.)
applies to the whole exercise or only to part b ...
@Civil_Disobedient ?
I do not believe I gave away the full answer for either part (a) or (b). My "tutorial" is related to the figure posted by OP, which is a rectangle in the xy-plane. That rectangle has one corner at the origin while the one described in part (a) of the question has its equivalent corner at point (a,c). Furthermore, I did not post the result of the double integration which is what part (a) requires. As for part (b), the rectangle described in the question is in the yz plane, it involves a completely different integral and I have said nothing about setting that up. Anyway, thank you @BvU, for continuing to "like" the post. I tried to provide the rationale behind setting up a double integral.
No offence intended...
We haven't heard from @Civil_Disobedient whether b) only or a) and b) have to be answered in the form of an integral ?
Whatever, I'd like to see @Civil_Disobedient provide the outcome for part b) in the form of an evaluated integral as well ... in short: what's the result ?
I agree with all of the above.
I fully agree.
The integral here makes sense, but shouldn't the boundaries of each integral correspond to the integrals of the sides of the rectangle? i.e bounds of x-axis for part a should be between a and b and the integral for the y-axis be between c and d?
The integral form applies to both part a and b I believe
re-read #9
Yes, a to b and c to d. Instead of using the problem as worded, he constructed the integrals based on the picture you provided from a similar problem. In that picture one corner of the rectangle was at (0,0) and the other corner was at (a,b)
  • · Replies 17 ·
