Finding the inductance of a coil
  • Thread starter Thread starter fishingspree2
    Coil Inductance
A circular coil with a radius of 0.10 m and 30 turns is subjected to an external magnetic field of 2.60 mT, resulting in a magnetic flux of 2.45 mW when no current flows. When a current of 3.8 A is applied, the net magnetic flux in the coil becomes zero, leading to confusion about calculating inductance. The correct inductance is derived using the formula L = N*flux/current, but the initial assumption of zero flux is incorrect since inductance depends on geometry and not just flux. The discussion emphasizes the need to consider the magnetic field produced by the solenoid itself to find the inductance accurately, ultimately leading to the correct inductance calculation of 0.645 mH.
fishingspree2
A circular coil has a radius 0.10 m and 30 turns. An external magnetic field 2.60 mT is perpendicular to the coil. a) If there is no current, find the magnetic flux in the coil.
b) When current = 3.8 A in some direction, there is no more net flux in the coil. Find the inductance.
I can do a) but I don't understand b. the correct answer of b) is 0.645 mH
a) flux = NB*PI*r^2 = 2.45 miliweber, this is the correct answer
b) L = N*flux / current. If I set flux=0 then I get inductance = 0, which makes no sense because inductance only depends of the geometry.
Please help =(
Suppose the external magnetic field didn't exist. What would be the magnetic field created by the solenoid? Net field is 0 when this is equal to 2.60 mT.
I set B = -2.60 mT
which means that L = N*flux / current = n*-2.60 mT / current?
= (30*2.60*10^-3)/3.8 = 0.0205 H
not correct =(
The magnetic field produced by the solenoid is B=μ0*N*I/L. When B=2.6 mT, net magnetic field is 0, so B=2.6 mT when I=3.8 A.
Now, what would be the equation for the flux through the solenoid, created by the solenoid itself? You can then find L using L = N*flux / current.
Ok, B = μ0*n*i
the length of one turn is 2*Pi*R, the total length of the coil is N times that, so 2*Pi*R*N
n = number of turns / total length = N /[ (2*Pi*R*N) = 1 / (2*Pi*R)
so that B = μ0*i / 2*Pi*R
flux = B*Area = B*Pi*(R^2) = μ0*i*r / 2
so that L = N*flux / i = μ0*r*N / 2 = 1.88 * 10^-6 W, wrong answer
I have also tried multiplying the flux by N since there are N turns
please help =(
Ideasrule told you that ...
B=2.6 mT when I=3.8 A ,,,,,, So find L the length of the solenoid by this equstion :
B=μ0*N*I/L
Where ,
B = 2.6e-3 T
N = 30 turns
I = 3.8 A
So L = ?
Then substitute the value of L in this equation to find the Inductance of the Solenoid :
L Solenoid's Inductance = μ0*N2*A / L Length Found
Thats it .
Just for more clarification here are the steps to get the last equation for solenoid's inductance :
B Solenoid = μ0*n*I
n = N/L , So B Solenoid = μ0*N*I/L
\phi B = N*B*A*Cos(00)
So , \phi B = N*(μ0*N*I/L )*A*Cos(00)
Cos(00) = 1
So , \phi B = μ0*N2*I*A / L
The emf induced in N turns is N times the emf in one turn :
\epsilon = - d\phi B / dt
\epsilon = - ( μ0*N2*A / L ) * (dI/dt)
Finally the inductance :
L Solenoid's Inductance = - \epsilon / (dI/dt)
We will get finally :
Good Luck ...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
