Finding the intersection points of the two lines in space
To find the intersection point of the lines L1 and L2, set their x, y, and z equations equal to each other. Start by equating the x-values to solve for either parameter t or s, then substitute back into the other equations to find corresponding values. After determining t and s, check if the resulting z-values from both lines match; if they do, the lines intersect at that point. If the z-values differ, the lines are skew and do not intersect. This method effectively determines the intersection coordinates for the given lines in space.
macaulay
given the lines in space
L1 : x = 2t + 1, y = 3t + 2, z = 4t + 3
L2 : x = s + 2, y = 2s + 4, z = -4s – 1
Find the point of intersection of L1 and L2.
How do i solve this?
Mathematics news on Phys.org
set the x's equal to each other and solve for either t or s, then plug into the other variables to get the coordinates
Another method ....
Set the x's and y's equal to each other
2t+1 = s+2
3t+2 = 2s+4
solve the system for t and s
Plug the resulting values for t and s into
z=4t+3 and z = -4s-1
to be sure they give the same value for z
If they do not, the lines are skew
If they do, then the values for t and s give the
coordinates of the intersection point for x,y and z
thank u very much mr. paulfr and woopydalan...i appreciate your replies to my question.. thank u very much =)
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
