Finding the mass of a solid, using Spherical Coordinates.
The problem involves finding the mass of a solid defined by specific boundaries in spherical coordinates, with a given density function. The solid is bounded above by the surface defined by z = √(25 - x² - y²) and below by the plane z = 4.
  • Mixed
  • Participants discuss the transformation of the boundaries into spherical coordinates, particularly the limits for the radial variable ρ and the angle φ. There is uncertainty regarding the correct limits for φ, with some suggesting it should be arcsin(1/5) while others propose it should be arcsin(3/5) or arccos(4/5).
There is active engagement with multiple interpretations of the limits for φ and ρ. Some participants express confusion about the correct boundaries and the use of z = 1 versus z = 4. Guidance has been offered regarding the transformation process, but no consensus has been reached on the final limits.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. The discussion reflects a collaborative effort to clarify the setup and assumptions of the problem.
supermiedos
Find the mass of the solid bounded from above z = √(25 - x2-y2) and below from z = 4, if its density is δ = k(x^2 + y^2 + z^2)^(-1/2).
m = ∫∫∫δdV
The plane z = 4 is transformed into ρcosφ = 4, that is, ρ = 4secφ. And x^2 + y^2 + z^2 = 25 is ρ = 5. θ goes from 0 to 2π. But I'm struggling finding the limits for φ (the azimuth). I think φ must go from 0 to π/2, but I can't get the correct answer (which is kπ). The book suggests that I must express the upper limit for φ as an inverse cosine, but why is that? From the figure I can see φ goes from 0 to 90°.
Thanks in advance
Yes, \rho, the radial variable, goes from 0 to 5 and \theta, the "longitude" goes from 0 to 2\pi. \phi, the "co-latitude" goes from 0 to arcsin(1/5) since line making angle \phi with the z-axis, to a point on the hemi-sphere with z= 1, is the hypotenuse of a right triangle with "opposite side" 1.
Wait, ρ goes from 0 to 5? I tought ρ went from 4secφ to 5. And why do you use z = 1?
You are correct for ##\rho## and ##\phi## from 0 to ##\arcsin(\frac 3 5)## or ##\arccos(\frac 4 5)##.
Thanks both of you for your help. The result it's correct :)
I used z= 1 because I misread your post, thinking the base was 4 places below the top, at z= 1, rather than at z= 4. Of course, you should use z= 4, not z= 1.
Thank you, and thanks for the idea of the triangle.
