Finding the work done by Spiderman
  • Thread starter Thread starter member 731016
    Work Work done
94 replies · 8K views
member 731016
Please see below
Please see below
For this problem,
The answer is ##-4.70 kJ##. I am not sure what I am doing wrong.
My working is
## W = mgr\cos\theta ##
## W = mgr\cos150 ## (since angle between ##\vec g## and ##\vec r## is 150 degrees)
## W = -mgr\frac {\sqrt{3}}{2} ##
## W = (-80)(9.81)(12\sin60)(\frac {\sqrt{3}}{2}) ##
## W = -7063.2 J ##
Would some please be to offer some guidance?
Many thanks!
Thank you for your replies @haruspex and @Lnewqban!
##W = \vec F \times \vec r ##
## W = Fr\cos\theta ## from definition of dot product
F = mg since we are finding work done gravity
##W = mgr\cos\theta ##
Many thanks!
No, that’s the cross product. You want the dot product.
But leaving that aside, what relationship does ##\vec r## need to have to the force in order for the result to be work done by the force?
Sorry, yeah I forgot to do the dot product.
##\vec r## can be at any angle expect ##\theta = 90, 270, 450, n + 180## with the force
Many thanks!
I suggest you redo the problem with 1 degree rather than 60 degrees and you should see your mistake.
No, I mean the functional relationship. "##\vec r## is the displacement through which …".
Thank you @PeroK! I have tried that now. I got a number much under the answer now.
Many thanks!
Thank you @haruspex! Spider man moves?
Thank you !
Thank you !
Wait, I'm sorry - I have objected to the wrong line.
It's this one:
Not according to your diagram.
Many thanks!
Who is F and who is W in your diagram?
The weight of Spiderman, force which has done some work, has a unique direction of action: vertical.
Sorry I don't understand how the angle between the line extending from the displacement vector and the force of gravity is not 150 degrees.
I think I must have got the angles wrong or something in the diagram. Could someone please show me how to correctly calculate the angle between the displacement and weight vector?
F is the force of gravity acting on spider man and W is the work done by the force of gravity on the spider man.
Many thanks!
You have a triangle with two equal sides (length of the wire in the two positions) and 60 degree angle at the top. What are the other two angles?
Thank you for your reply @nasu!
I did not see that it was an isosceles triangle! The two other angles will be 60 degrees each.
I will redo my diagram now.
Many thanks!
nasu said:
Actually is equilateral, isn't it?
True, you are right! I did not know that an equilateral triangle is a special case of an isosceles triangle!
Many thanks!
Here is the new diagram with the equilateral triangle:
It still seems to give ##\theta = 150## thought. I'm still not sure, how to find the correct ##\theta##.
Many thanks!
Many thanks!
What makes you think the angle between the mg line and the dashed orange line that goes up to the right is 90°?
There are no 90 degrees angles, as you mistakenly show in your first diagram. How can you get 150?
Thank your for your reply @haruspex !
Sorry, I did not mean the angle between the mg line at the dashed orange line at 90 degrees. It should be,
Many thanks!
Sorry, what do you mean there are no 90-degree angles?
I got 150 degrees since there is a right angle between the two dotted orange lines and a 60 degree angle between and the red mg line and dotted orange line.
Many thanks!
Many thanks!
Ok, but how do you get 60° between mg and the lower dashed orange line?
It would help if you were to draw it a bit more accurately.
Many thanks!
No, there is not. What is that dotted orange line? If you draw it perpendicular ot the direction of ##\Delta \vec{r} ## then the other angle is not 60 degrees. But you don't need that dotted line. Just draw the weight where ##\Delta \vec{r} ## starts.
Thank you for your reply @haruspex!
I think I got 60 degrees from the corresponding angles theorem.
Many thanks!
Thank you for your reply @nasu! I will do that.
Many thanks!
Many thanks!
That angle is 60 degrees but the extension of the black line is not along the dotted line that you show in the previous drawing. You see here that the black line is not at 90 degrees relative to this dotted orange line.
You keep bending lines.
Go back to your diagram in post #1, draw it accurately, and don't mark in right angles that you cannot prove are right angled.
