- 13,438
- 8,113
Yes. The concern with differentials is distracting and the drawings could be done more clearly -- in particular, labelling the angle you are calling ##\theta##. But I agree with the conclusion.Callumnc1 said:Is my proof for θ=90+ϕ geometrically correct?
It might make it easier to evaluate the resulting integral if you would write ##\cos ( 90 + \phi )## as ##-\sin \phi##.
Personally, I would have looked at the formula for the projection of a vector normal to a [oriented] surface. That involves ##\sin \theta## where ##\theta## is the angle the vector makes with respect to the surface. In this case, the displacement vector makes an angle of ##- \phi## with respect to a horizontal surface. The projection thus involves ##\sin -\phi = - \sin \phi##.
You can get the dot product of two vectors by taking the projection of one in the direction of the other and multiplying the magnitude of the one by the [signed] magnitude of the projection of the other.
Actually, I would have been sloppy with the sign convention, ignored the orientation of the surface, looked at ##\sin \phi## and then reasoned that the displacement and gravity are pointing generally away from each other and inverted the sign of the resulting path integral.
Actually, I would have recognized a conservative field, reasoned that all path integrals between a particular pair of endpoints across a conservative field will yield the same result and either picked a trivial path or computed the potential difference.
But we can definitely get to work evaluating the integral.
