Finding the work done by Spiderman
  • Thread starter Thread starter member 731016
    Work Work done
94 replies · 7K views
haruspex said:
Horizontal is the orientation of a line or a plane, not a particular height. In an apartment block, all the floors are horizontal, preferably.
Thank you for your reply @haruspex!
Callumnc1 said:
Do you mean it was possible to get the chains a bit above the vertical?
A swing normally hangs straight down. The chains are vertical. "Vertical" is in the direction of gravity. "Horizontal" is perpendicular to this.
As you swing back and forth the angle (measured from the vertical center line) of the chains reaches larger and larger peaks depending on how hard you pump.
If you pump hard enough, the peaks can reach 90 degrees. That is, the chains at the top of the arc are horizontal.
For a child swinger, problems arise when you pass the horizontal. When you reach the top of the arc and swing back down, the chains will have gone slack. You will fall downward on slack chains until they come taut again in an inelastic collision. The collision is jarring and, hence, dangerous. This collision also absorbs energy. Once you reach this situation, you can no longer pump gradually, adding a little energy with each oscillation. Instead, you need to inject all of the excess energy required to surpass the horizontal anew on every half cycle. It becomes hard work. [Plus, you are spending the next quarter cycle trying to get back to a stable orientation when you should have been prepping for the pump action at the bottom -- it keeps you busy dancing on the edge of control]
Reply
Thank you for your help @jbriggs444 ! I think I understand about what you were meaning now :)
Callumnc1 said:
Thank you for very much your reply @haruspex !
Sorry, I am having trouble visualizing this situation, could you kindly draw a diagram? I think this will also help me understand why angular momentum is not conserved in this situation
Many thanks!
During the part of the process I described, the ant running to one corner, I took angular momentum as conserved. But the result is that the mass centre of the ant+bob is displaced from being vertically below the pivot. So now gravity exerts a torque about the pivot.
Reply
Callumnc1 said:
Homework Statement:: Please see below
Relevant Equations:: Please see below
For this problem,
The answer is ##-4.70 kJ##. I am not sure what I am doing wrong.
My working is
## W = mgr\cos\theta ##
## W = mgr\cos150 ## (since angle between ##\vec g## and ##\vec r## is 150 degrees)
## W = -mgr\frac {\sqrt{3}}{2} ##
## W = (-80)(9.81)(12\sin60)(\frac {\sqrt{3}}{2}) ##
## W = -7063.2 J ##
Would some please be to offer some guidance?
Many thanks!
The work done is proportional to the difference in the height from the ground, which means that
W=mg(h2-h1), which is also the difference in the potential energy of Spiderman.
The difference in height is: l-l cos 60=12-12 cos 60=6 m.
[Solution redacted by the Mentors]
Reply
Ok thanks you for your reply @haruspex!
That helps a bit more :) I will draw a diagram of the situation you describe then post it soon. I find diagrams quite helpful for understanding the setup.
Many thanks!
W=mg(h2-h1)=6*9.8*80=4704 J=4.704 kJ
Thank you for your reply @Jake357 !
Third method to solve the work done by spider man:
I think we can solve this using the work integral with respect to theta and have the limits of integration as the initial angle spider man makes with the vertical and the finial angle spider man moves with the vertical.
I think we have to integrate with respect to theta, because for each differential displacement of spider man along his path the differential angle between spider man's weight and his differential displacement vector is not the same.
##W = \int_{\theta_i}^{\theta_f} mgr\cos\theta dr##
##W = \int_{\theta_i}^{\theta_f} mgr^2\cos\theta~d\theta##
In progress...
Many thanks!
Please define r and θ in that equation.
Reply
r is the radius to where the rope hangs from so is the length of the rope
##\theta## is the angle the rope makes with the vertical
Many thanks!
Many thanks!
So r is a constant, but you integrate wrt it?
Reply
I think take it out of the work integral that will wrt to theta
Many thanks!
Many thanks!
Right.
Don't just throw integrals together that seem to have the right ingredients. Think what the integral is saying.
In the present case, you are considering spiderman moving as the rope swings, so the independent variable is the angle. As it swings through a small angle ##d\theta##, Spiderman moves a distance (what?) at an angle (what?) to the vertical force (what?) thereby doing work (what?).
Reply
haruspex said:
Right.
Thank you for your reply @haruspex ! That is good advice! I have tried to include my reasoning below.
Since we know that the when the spider man moves an infinitesimal displacement ##\vec {ds} = dx\hat i + dy\hat y## when a ##F_g## is applied by the earth
## dW = F_g \cdot \vec {ds} ##
We know the path spider man travels though is a circular arc of length ##S = r\theta## (The arc length is dependent of the theta)
Given that the arc length of the path is ##S = r\theta##, we take the derivative of arc length with respect to theta giving ## ds = r\theta d\theta##
## dW = Fr\cos\theta d\theta ## Where ##d\theta## is the angle between the weight and displacement vector ##\vec ds## tangent to the circular path at each point
Ok so know we need to get ##\cos\theta## in terms of the angle the rope makes with the vertical ##\phi## (I just defined that variable)
However, do you please know how do you do that?
I think maybe from geometry (if I proved it correctly) ##\theta = \phi##
Many thanks!
Callumnc1 said:
the angle the rope makes with the vertical ϕ (I just defined that variable)
When you wrote S=rθ, weren’t you taking θ to be that variable?
Reply
I think I changed the variables. I now take ##\phi## as the angle between the vertical and the rope and ##d\theta## as the angle between the force of gravity and differential displacement ##\vec {ds}##
Many thanks!
Then this is wrong:
Please update those equations using your new definitions.
Edit: just noticed your step from ##S = r\theta## to ## ds = r\theta d\theta## is also wrong.
Reply
haruspex said:
Then this is wrong:
I see my mistake, it should be ##ds = rd\theta##
I will post the update equations soon.
Many thanks!
Here are the new equations @haruspex ,
We start with ## dW = Fr\cos\theta d\theta ##
And we must integrate from ##\phi_1## to ##\phi_2## so ## dW = \int_{\phi_1}^{\phi_2} Fr\cos\theta d\theta ##
Therefore, since ##\theta## depends on ##\phi## we must get ##\theta## in terms of ##\phi##. I did this geometrically and proved that ##\theta = \phi##.
Am I correct?
Many thanks!
Am I correct?
Many thanks!
If ϕ is the angle between the vertical and the rope then S=rφ.
When ϕ=0, what is the angle between ##\vec ds## and the gravitational force?
Reply
True I did not realize that s =rφ.
I should then take the of the new arc length equation with respect to phi to get ##\frac{ds}{d\phi} = r##
When ##\phi## is zero, then ##\theta## the angle between ##\vec {ds}## and ##F_g## is 90 degrees.
Are you trying to get me to find the relationship between ##\phi## and ##\theta## by considering a few physical situations?
If I consider the second case where ##\phi## is 90 degrees, then the angle between ##\vec {ds}## and ##F_g## is 180 degrees, correct?
Is there a way to find the relationship between ##\phi## and ##\theta## without considering intuitive cases along the circular path?
Many thanks!
Callumnc1 said:
Is there a way to find the relationship between ϕ and θ without considering intuitive cases along the circular path?
Of course: draw the right diagram. The special cases are just an easy way to check your answer.
If you thought you had proved a different relationship, try to see where that proof went wrong.
Reply
Based on my special cases in post #81,
1. ##\phi = 0## then ##\theta = 90##
2. ##\phi = 90## then ##\theta = 180##
It looks to me like the relationship is ##\theta = \phi+ 90## so theta is always a phase shift of 90 degrees ahead of phi.
I will draw a diagram again to prove this and post it soon!
Many thanks!
Here is are my diagrams @haruspex
Could you please give me some more guidance, I am still getting ##\theta = \phi##
But I guess I'm meant to be looking at differential displacement so I can see here that ##\theta = 180##
many thanks!
many thanks!
You have drawn ##\theta## as the angle the final displacement makes to the vertical. You defined it as the angle the displacement element ##\vec ds## makes to the vertical at an intermediate point.
Draw a diagram with the rope at two angles to the vertical, ##\phi## and ##\phi+d\phi##.
The displacement element is length ##r.d\phi##. Note that it is at right angles to the rope.
Reply
I guess it sort of makes sense to consider incremental changes in phi if we are trying prove the change in theta. I will try that!
Many thanks!
Here are the new diagrams @haruspex !
I'm assuming the displacement vector is only at a right angle to the rope where it extends from (the red line in this case). I'm not sure if the displacement vector makes at right angle with the dark orange line (finial rope position)
Many thanks!
##ds## is (or behaves like) an infinitesimal. The incremental displacement is infinitesimally close to being at right angles to both the initial and final angles. Its angle differs from the perpendicular by only ##d \phi## at most.
But that is window dressing. Surely you are after the incremental work done. This should be the vector dot product of the force of gravity, ##\vec{mg}## and the incremental displacement, ##\vec{ds}##.
Reply
Thank you for your reply @jbriggs444 !
Oh ok that makes sense, now. I have added that too my new diagram (which is very not too scale):
Yes I think I am after the incremental work (## dW = \int_{\phi_1}^{\phi_2} Fr\cos\theta~d\phi ##) in terms of phi which I will integrate from ##\phi_1 = 0## to ##\phi_2 = 60## (Where ##\theta## is the angle between the differential displacement and spider man's weight).
Would you please know how to get theta in terms of phi from the diagram? I think (by considering two cases from post #83) that ##\theta = \phi + 90##
Many thanks!
I think I may have found the answer!!!
First method:
If we start with the big triangle,
Then,
##\phi + d\phi + 90 + \theta_2 = 180##
##\theta_2 = 90 - \phi - d\phi##
Now for the small triangle,
##90 + \theta_2 + \theta_1 = 180##
## \theta_1 = 90 - \theta_2##
## \theta_1 = 90 - (90 - \phi - d\phi)##
## \theta_1 = \phi + d\phi##
Therefore since ##\theta = 90 + \theta_1## (since ##theta_1## is vertically opposite)
Then ##\theta = 90 + \phi + d\phi ≈ 90 + \phi## since ##d\phi## is a differential
Second method:
I believe you could have also found ##\theta_2## from the medium size triangle,
Where in this case
##\theta_2 = 90 - \phi##
##\theta = 90 + \phi## without having to make the approximation in the first method
Is my proof for ##\theta = 90 + \phi## geometrically correct?
Many thanks!
