Finding the work done by Spiderman
94 replies · 8K views · last reply
Callumnc1 said:
Is my proof for θ=90+ϕ geometrically correct?
Yes. The concern with differentials is distracting and the drawings could be done more clearly -- in particular, labelling the angle you are calling ##\theta##. But I agree with the conclusion.
It might make it easier to evaluate the resulting integral if you would write ##\cos ( 90 + \phi )## as ##-\sin \phi##.
Personally, I would have looked at the formula for the projection of a vector normal to a [oriented] surface. That involves ##\sin \theta## where ##\theta## is the angle the vector makes with respect to the surface. In this case, the displacement vector makes an angle of ##- \phi## with respect to a horizontal surface. The projection thus involves ##\sin -\phi = - \sin \phi##.
You can get the dot product of two vectors by taking the projection of one in the direction of the other and multiplying the magnitude of the one by the [signed] magnitude of the projection of the other.
Actually, I would have been sloppy with the sign convention, ignored the orientation of the surface, looked at ##\sin \phi## and then reasoned that the displacement and gravity are pointing generally away from each other and inverted the sign of the resulting path integral.
Actually, I would have recognized a conservative field, reasoned that all path integrals between a particular pair of endpoints across a conservative field will yield the same result and either picked a trivial path or computed the potential difference.
But we can definitely get to work evaluating the integral.
Thank you so much for your reply @jbriggs444 !
Yeah true, there is a much easier method if I had recognized the conservative field! Sorry, what did you find distracting about my concern with differentials?
Was it the fact that first method I had to make an approximation and the second I did not (due to the choice of triangles)
I will post the integral
Many thanks!
Here is the integration @jbriggs444 !
##W = -Fr\int_0^{60} \sin\phi d\phi##
##W = mgr\cos60= \frac {mgr}{2}## which is correct!
Many thanks!
Well, a drawing of an isosceles triangle with two right angles is a bit distracting.
