Finding v(t) for a velocity dependent force
12 replies · 6K views · last reply
littlehonda
Given the one-dimensional retarding force F=-Ae^(-[tex]\alpha[/tex]v) find an expression for v(t).
F = m(dV/dt)
A and [tex]\alpha[/tex] are constants, v is instantaneous speed.
Im not sure how to frame the idea of integrating a velocity dependent force. Can I take simply integrate and use
v= -Ae^(-[tex]\alpha[/tex]v)t
or should the v be eliminated from the right hand side. I tried doing that by dividing the left by e^(-[tex]\alpha[/tex]v) and then doing a e^u du type integration but the answer i came up with didn't seem reasonable.
just looking for a little hint or push here, thanks!
thanks for responding gabba,
I think that I tried the separable differential equations method but couldn't make sense of the answer
what i did was
e^([tex]\alpha[/tex]v) dv = -Adt
1/[tex]\alpha[/tex](e^([tex]\alpha[/tex]v)-e^([tex]\alpha[/tex]v0)) = -At
i'm not sure what this means though or where to go from here
what i did was
[tex]\int e^{\alpha v}dv =\frac{e^{\alpha v}}{\alpha}+C_1[/tex]
And
[tex]\int-Adt=-At+C_2[/tex]
[tex]\implies \frac{e^{\alpha v}}{\alpha}=-At+C_3[/tex] where [itex]C_3 \equiv C_1-C_2[/itex]
Multiply both sides of the equation by [itex]\alpha[/itex] and then take the natural log. What initial conditions are you given?
ok so that's where I got to pretty much, the C1+C2=C3 makes sense.
Here is all the information given
A= 1/m/s^2
[tex]\alpha[/tex]=.1 s/m
v0= 20 m/s
I assume [itex]v_0=v(t=0)[/itex]? If so, you can solve for [itex]C_3[/itex].
F = m(dV/dt)
what i did was
Your original equation is
[tex]m\frac{dv}{dt}= -Ae^{-\alpha t}[/itex]<br /> which separates as <br /> [tex]e^{\alpha v}dv= -A/m dt[/tex]<br /> (you dropped the "m")<br /> Integrating,<br /> [tex]-\frac{1}{\alpha}e^{\alpha v}+ C= -(A/m)t[/tex]<br /> Assuming that your [itex]v_0[/itex] is the velocity when t= 0, <br /> [tex]-\frac{1}{\alpha}e^{\alpha v_0}+ C= 0[/tex] <br /> so <br /> [tex]C= \frac{1}{\alpha}e^{\alpha v_0}[/tex]<br /> so <br /> [tex]-\frac{1}{\alpha}\left(e^{\alpha v}- e^{\alpha v_0}\right)= -(A/m)t[/tex]<br /> which is just what you have (except for the "m").<br /> <br /> Are you concerned with solving for v?<br /> [tex]e^{\alpha v}- e^{\alpha v_0}= (A\alpha/m)t[/tex]<br /> [tex]e^{\alpha v}= (A\alpha/m)t+ e^{\alpha v_0}[/tex]<br /> Now take the logarithm of both sides.[/tex]
(e^20[itex]\alpha[/itex])/[itex]\alpha[/itex] = C3
C3 = 73.8
v(t) = (ln(-At[itex]\alpha[/itex])+ ln(73.8[itex]\alpha[/itex]))/[tex]alpha[/tex]
sorry if I am a little slow with this, am I making an error here?
C3 = 73.8
Yes, you are making a few errors.
To start with, Halls pointed out that you dropped the mass of the object from the differential equation...when you include it, you should get
[tex]\frac{me^{\alpha v}}{\alpha}=-At+C_3[/tex]
Multiply both sides of the equation by alpha/m:
[tex]\implies e^{\alpha v}=\frac{\alpha}{m}(-At+C_3)[/tex]
Then take the natural log of both sides
[tex]\alpha v =\ln\left(\frac{\alpha}{m}(-At+C_3)\right)[/tex]
You can take it from there...
I was careless putting the force equation up, the right side of the equation also contains a m to cancel the one on the left.
v= (ln([itex]\alpha[/itex](-At+C3)))/[itex]\alpha[/itex]
Solving for C3
C3 = (e^v0[itex]\alpha[/itex])/[itex]\alpha[/itex]
at V(0) t=0
C3 = 73.89
v= (ln([itex]\alpha[/itex](-At+73.89)))/[itex]\alpha[/itex]
hey thanks a lot both of you guys!
hate to keep pestering but if I want to find x(t) I just integrate dx/dt and find a new constant C3 using the initial condition x(0) t=0?
