Finding Value of Phi*k(x) in Basis Function Method
ohhhnooo
Psi(x) = Sumationn CnPhin(x)
in order to find Cn, i have to multiply both side of the above equation by Phi*k(x) and take the integral. The result is Ck if n = k. My question is what is the value of Phi*k(x)?
i know that multiplying both side of the equation by Phi*k(x) would make the function orthonormal when n != k, and normalize when n = k. But i don't know how to find it.
Is this:\psi(x)=\sum_{n}C_{n}\phi_{n}(x)(1)...?
Is the basis \{\phi_{n} \}_{n=1}^{\infty} orthonormal...?If so,then multiply (1) by \phi_{k}^{*}(x),sum after "k" & integrate after "x"...
Daniel.
what is the condition for \{\phi_{n} \}_{n=1}^{\infty} to be orthonormal? thanks
Per definition, if the following holds, the set \{\phi_{n} \}_{n=1}^{\infty} is orthonormal:
\langle \phi_i|\phi_j\rangle = \int \limits_{-\infty}^{+\infty}\phi_i^*(x)\phi_j(x)\; dx=\delta_{ij}
can you provide an example?
Hidrogenoid functions are an interesting example.SHO eigenfunctions are other example.Rigid rotator is another example.Infinite square well and so on,and so forth.
Daniel.
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
