Finding velocity of falling object
To determine how much of a one-meter chain can dangle off a table before it falls, the force of the chain being pulled off must equal the force of friction, which is influenced by the coefficient of friction of 0.15. The discussion suggests using differential equations to analyze the acceleration of the chain as it dangles and begins to fall. An alternative approach is to consider the energy in the system, factoring in friction as an energy drain. However, the complexity increases when accounting for the chain's rotation and potential oscillations during the fall. Understanding these dynamics is crucial for accurately predicting the chain's behavior upon hitting the floor.
jubin
A one meter chain that weighs one Newton sits on a flat horizontal table that is one meter
from the floor. The coefficient of friction between the chain and table is 0.15. How much of the chain can dangle off the table until the chain pulls itself onto the floor?If it starts to fall from this position of "maximum dangle", how fast is the chain moving when it first hits the floor
Do you have any experience with differential equations? Because if you do, I'd suggest using one to determine "jerk" of the chain.
yes i have an experience with differential equations.
Set up a differential equation for acceleration in terms of how much chain's dangling off. Solve it. My previous post stands corrected, acceleration, not "jerk."
Also note that you'll have to find the maximum dangle by setting the force of the chain being pulled off equal to the force of friction. From here, I'd imagine you'd get a state of no change.
is there another way to solve this problem without using differential equations?
Looking at the energy in the system should work, if you include the friction as energy drain.
However, a real chain would rotate while falling (probably with some oscillations in addition), which makes the system much more complex as it is intended here.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
