Finding Volume using integration
  • Thread starter Thread starter Mcbrown108
    Integration Volume
The problem involves finding the volume of a solid formed by rotating a region defined by the equation (e^(1x)+2)/y=0, bounded by x=0 and x=0.9, about the y-axis. The subject area pertains to calculus, specifically the application of integration techniques for volume calculation.
  • Participants discuss the use of the disk method for volume calculation and question whether the rotation is about the x-axis or y-axis. There is confusion regarding the bounds and the orientation of the discs used in the integration.
The discussion is ongoing, with participants exploring different interpretations of the problem setup. Some guidance has been offered regarding the orientation of the discs, suggesting that they should be horizontal and centered on the y-axis. There is no explicit consensus yet on the correct approach.
Participants are grappling with the implications of rotating around the y-axis versus the x-axis, and there is uncertainty about how to correctly set the bounds for integration based on the given equations.
Mcbrown108
Find the volume of the solid formed by rotating the region enclosed by:
(e^(1x)+2)/y=0/x=0/x=.9
about the y axis
Probably disk method i would assume:
V=pi*int((f(x)^2) dx from bounds a to b
V= pi*int(e^(1x)+2)^2) a=0 b=.9
v=pi*int(e^(2x)+4) a=0 b=.9
v=pi*(1/2e^(2x)+4x)
v=pi*(1/2e^(2(.9))-(1/2e^0)+(4(.9)
v=pi*(3.025)-(1/2)+3.6
v=6.125pi
But my answer is not correct.
about the y axis
Hi Mcbrown108! :smile:
Isn't that for rotation about the x-axis? :cry:
Oh yeah. so then would i change my bounds to a=-.9 b=.9
that doesn't seem to work either
It's not your bounds that are wrong … it's your discs.
Your discs should be "horizontal" discs, centred on the y-axis. :smile:
So i should plug in the given x's to get y's for my bounds?
I've no idea what that means, but I'm going to guess the answer is … "YES!"
Go for it! :smile:
  • · Replies 105 ·
12K
  • · Replies 19 ·
