Finding weight of a mass on an accelerating and braking elavator
Zach's weight before the elevator starts braking is calculated using the formula F = mg, where m is his mass (78 kg) and g is the acceleration due to gravity (approximately 9.8 m/s²), resulting in a weight of about 764 N. While the elevator is braking, the effective weight can be determined by adding the deceleration of the elevator (3.4375 m/s²) to the gravitational acceleration, leading to a new force calculation of F = (9.8 + 3.4375) * 78 kg, which gives approximately 1032.5 N. The final answer needs to be expressed with two significant figures, which simplifies to 1000 N. The discussion emphasizes the importance of understanding the difference between weight under constant velocity and weight under acceleration. Proper application of physics principles is crucial for solving such problems accurately.
alexas
Zach, whose mass is 78 kg, is in an elevator descending at 11 m/s. The elevator takes 3.2 s to brake to a stop at the first floor.
What is Zach's weight before the elevator starts braking?
What is Zach's weight while the elevator is braking?
F = mg
F = ma ??
I was thinking...
F = mg
So F = (78kg)*(11m/s) ?
The second question i was completely clueless on...
but an idea of mine was...
F = ma
a = (11m/s)/(3.2s) = 3.4375 m/(s^2)
F = (78kg)(3.4475) ?
F = mg
F = ma ??
I was thinking...
F = mg
F = ma
Your final idea gave you the right acceleration (deceleration) for the elevator, but not the force that some scales would measure.
What about his original weight standing still or moving at constant velocity? It's not m*v as you've shown in part a)
I was thinking...
F = mg
uhh? :confused:
F = ma
if the braking deceleration was 0, would the weight be 0? :wink:
Try drawing a free body diagram to see the forces involved. That will make your life simpler.
I figure for the first question that if the speed is constant that accleration is zero so it would simply just be mass*gravity.
But for the second one since i need to factor in the deceleration i was thinking
(9.8 + 3.4375)*(78kg)
Is this correct?
Is this correct?
That is correct.
I don't get it. I type in the answer and it says i have a rounding error. lolll
My final answer was: 1032.525
it tells me "Express your answer using two significant figures."
So 1032.52 or 1032.53 neither one works.
erm :redface: … that's six sig figs! :wink:
Yeah they wanted the answer as 1000, :P
Thanks for the help everyone.
