First step of this simple limit problem
  • Context: Undergrad
  • Thread starter Thread starter sachin_naik04
    Limit
11 replies · 2K views
sachin_naik04
First step of this simple "limit" problem
Lim....X^3-3x^2+4
x->2... X^4-8x^2+16
In the above "limit" problem i would like to know only the very first important step, the later part of the problem i will manage to solve as its easy, only the first step is a bit tricky
so what could be the first step of this problem
actually i am a B.com. student, please help me thanks in advance
l'hospital's rule applies nicely. if you haven't learned that, then just factor the numerator and denominator.
no i haven't learned any l'hospitals rule, but how do i factor the denominator as its x^4
i want to solve it without that l'hospital method, please help
oh i am hearing that l'hospitals rule is easy, i hope i will understand, so if possible u can also explain this rule to solve the first step of this problem or the other
but atleast something please
The denominator factors into (x2 - 4)2, which can be further factored into (x - 2)2(x + 2)2. The numerator can also be factored. Some obvious candidates are (x - 1), (x + 1), (x - 2), (x + 2), (x - 4), and (x + 4).
@Mark44
oh thanks a lot for your help really great
i will try it on my book and see if i have any difficulty, if yes then i will come back here
but one more thing in order to get that (x^2 - 4)^2 have u used your own mind or have u done some rough work
The fact that Mark44 wrote that in terms of [itex]x^2- 4[/itex] rather than x- 2 implies that he first recognized that [itex]x^4- 8x^2+16= (x^2)^2- 2(4)x^2+ 4^2[/itex] is of the form "[itex]u^2- 2au+ a^2[/itex]", the standard form of a perfect square. I would have done this in a completely different way:
The only reason you had a problem with that fraction was because both numerator and denominator go to 0 as x goes to 2. That tells you immediately that each polynomial has x- 2 as a factor. Divide the polynomial by x- 2 to find the other factor. Repeat if necessary.
I think u should try learning L'Hospital's rule too...all you have to do then is differentiate the numerator & denominator separately(only in cases: 0/0, ∞/∞, etc.) and then apply the limit.
Actually I would've gone with a combination of both Mark44's and Hallsofivy's ideas.
Firstly, looking at the denominator, yes it's a quartic ([itex]x^4[/itex]) but you can treat it as a quadratic in some other variable.
[tex]x^4-8x^2+16[/tex]
if you let [itex]x^2=u[/itex] you then have:
[tex]u^2-8u+16[/tex]
which is a quadratic. Factoring this gives you:
[tex](u-4)^2[/tex]
And then you can substitute [itex]u=x^2[/itex] back and factorize further as Mark44 has done.
For the numerator it is a cubic, so the above method cannot be used but you can then factor out (x-2) since when you substitute x=2 into it, you end up with 0. This of course means x=2 is a root of the equation.
After that you'll have a quadratic so it's straight-forward from there :smile:
well i understood the problem,thanks everyone a lot
now i have one more problem for the following simple limit
lim...3x(x2-7x+6)
x->3...(x+2)(x3+4x+3)
now if u see the above problem and substitute the value of "x" that is "3" then u get the answer as -9/35 therefore the denominator doesn't go to "0" and hence the answer but the textbook says the correct answer for this problem is 5/2, looks like we have to simplify the problem is it so, because i had heard that whenever the denominator does NOT go to "0" then we can directly substitute the value of x without simplifying the problem
so the question is should i directly substitute the value of "x", as the denominator does not go to "0" or i have to simplify it, if yes then why?
Since the denominator doesn't approach 0 as x approaches 3, you can simply substitute 3 in both the numerator and denominator. The value I get is also -9/35. If your book gets a different value, make sure that you are working the same problem as in your book.
