MHB Fishfood12m's question at Yahoo Answers regarding special integrating factors
To find the integrating factor for the differential equation ydx + (2xy - e^(-2y))dy = 0, first verify that the equation is not exact by comparing the partial derivatives. The integrating factor is derived from the expression (My - Nx) / N, leading to μ(y) = e^(2y) / y. Multiplying the original equation by this integrating factor makes it exact, allowing for straightforward integration. The solution to the ODE is given implicitly by C = xe^(2y) - ln|y|.
MarkFL
MHB
Here is the question:
Integrating Factor Help Please!?
I am preparing for a test and need to be able to find the integrating factor of problems similar to:
ydx + (2xy-e^(-2y))dy=0
All I want is how to find the integrating factor. From what I learned u'=U*(My - Nx) / N
That doesn't seem to work for me. Perhaps you can explain how to find it with step-by-step detail.
Thanks!
Here is a link to the question:
Integrating Factor Help Please!? - Yahoo! Answers
I have posted a link there so the OP can find my response.
Mathematics news on Phys.org
Hello fishfood12m,
We are given to solve:
$\displaystyle y\,dx + (2xy-e^{-2y})\,dy=0$
We should first verify that it is not exact:
$\displaystyle \frac{\delta}{\delta y}(y)=1$
$\displaystyle \frac{\delta}{\delta x}(2xy-e^{-2y})=2y$
Since the two partials are not equal, the equation is not exact.
Next, we look at the expression:
$\displaystyle \frac{\frac{\delta}{\delta y}(y)-\frac{\delta}{\delta x}(2xy-e^{-2y})}{2xy-e^{-2y}}=\frac{1-2y}{2xy-e^{-2y}}$
Since this does not depend on $x$ alone, we next look at:
$\displaystyle \frac{\frac{\delta}{\delta x}(2xy-e^{-2y})-\frac{\delta}{\delta y}(y)}{y}=\frac{2y-1}{y}=2-\frac{1}{y}$
Since this depends only on $y$, we compute the integrating factor as follows:
$\displaystyle \mu(y)=e^{\int2-\frac{1}{y}\,dy}=e^{2y-\ln|y|}=\frac{e^{2y}}{y}$
We now multiply the ODE by $\mu(y)$ observing we are losing the trivial solution $y\equiv0$:
$\displaystyle \frac{e^{2y}}{y}\cdot y\,dx + \frac{e^{2y}}{y}(2xy-e^{-2y})\,dy=0$
$\displaystyle e^{2y}\,dx + \left(2xe^{2y}-\frac{1}{y} \right)\,dy=0$
We can now easily see that the equation is exact. Even though you asked only for the integrating factor, I will go ahead and solve the equation.
Since our equation is exact, we may state:
$\displaystyle \frac{\delta F}{\delta x}=e^{2y}$
Integrating with respect to $x$ we get:
$\displaystyle F(x,y)=\int e^{2y}\,dx+g(y)=xe^{2y}+g(y)$
Now, to determine $g(y)$, we will take the partial derivative with respect to $y$ of both sides of the above equation and substitute $\displaystyle 2xe^{2y}-\frac{1}{y}$ for $\displaystyle \frac{\delta F}{\delta y}$:
$\displaystyle 2xe^{2y}-\frac{1}{y}=2xe^{2y}+g'(y)$
$\displaystyle -\frac{1}{y}=g'(y)$
Hence, integrating, and choosing the constant of integration to be zero, we find:
$\displaystyle g(y)=-\ln|y|$
And so we have:
$\displaystyle F(x,y)=xe^{2y}-\ln|y|$
Thus, the solution to the ODE is given implicitly by:
$\displaystyle C=xe^{2y}-\ln|y|$
Another way (without using integrating factor): we can write the equation in the form $\dfrac{dx}{dy}+2x=\dfrac{e^{-2y}}{y}$ which is linear on the dependent variable $x=x(y)$. Now, and using a well-known theorem, the general solution of the equation $x'+p(y)x=q(y)$ is
$xe^{\int pdy}-\displaystyle\int qe^{\int pdy}\;dy=C$
In our case, $p=2,q=\dfrac{e^{-2y}}{y}$ so,
$xe^{2y}-\displaystyle\int \frac{e^{-2y}}{y}\;e^{2y}\;dy=C$
Equivalenly:
$xe^{2y}-\ln |y|=C$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
