Floating Objects Affected by the Moon
  • Thread starter Thread starter CuriousGirl13
    Floating Moon
The Moon's gravity influences all objects, including those in water, causing tidal movements rather than circular motion. In a perfectly still water scenario, an object would not move in a circular pattern due to the Moon's gravity alone. Tidal effects, which are complex, result from the gravitational pull of the Moon, affecting the water's surface and potentially moving floating objects. If an object were levitated magnetically, it could theoretically move in larger circular paths, but this is not typical in natural conditions. Overall, the Moon's gravitational impact is primarily seen through tidal actions rather than direct motion of solid objects.
CuriousGirl13
This seems like a pretty simple question, but I haven't been able to find an answer yet. It has to do with gravity, so even though it's not really about special relativity, this seems like the best place to post it.
My question is; if an object were free-floating in perfectly still water, without currents, would it move in a circular patter due to the Moon's gravity? If not; under what conditions, if any, could the Moon's gravity move a solid object?
(p.s. I already know that the Moon moves the Earth's tectonic plates, I was wondering about smaller objects.)
Welcome to PF;
Are you thinking of tides here?
That would be classical physics.
The Moon's gravity affects the motion of everything just as the Earth and the Sun do... or anything with mass.
The details depend on the situation... under gravity the water, your example, would not be perfectly still ... as the moon passes you get a tide - everything gets tides.
The water would show some tides, so the object could be dragged along with the water.
It does not have to be a circle - tidal patterns are often complicated.
If you manage to let an object float over a perfectly balanced surface (magnetic levitation?), it could move in a bigger circle - at least in theory.
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 41 ·
  • · Replies 30 ·
  • · Replies 33 ·
  • · Replies 35 ·
  • · Replies 18 ·
  • · Replies 17 ·
