What is the formula for calculating the sum of ceiling values for two integers?
  • Thread starter Thread starter rayukpant
To calculate the sum of ceiling values for two integers 'n' and 'm', the formula is ceiling[(n+m)/2] + ceiling[(n-m+1)/2]. The discussion emphasizes analyzing two cases based on the parity of 'n' and 'm': both integers having the same parity (either both even or both odd) or having different parities (one odd, one even). In both scenarios, the ceilings can be explicitly determined, leading to a clearer evaluation of the sum. It is noted that the sum or difference of two even numbers or two odd numbers is even, while the sum or difference of one odd and one even number is also even. A key takeaway is that in any case, one of the expressions results in an integer while the other results in a half-integer.
rayukpant
For integers 'n' and 'm', find the value of ceiling[(n+m)/2] + ceiling[(n-m+1)/2].
Mathematics news on Phys.org
Consider the two cases separately, of
1. Either both even or both odd and
2. One odd the other even.
Just split it into cases.
Either
(1) m and n have the same parity (either both odd or both even); or
(2) m and n have different parities (one odd and the other even).
In both cases, you can explicitly find the ceilings in question.
can you please tell me more in detail as to how to consider those two separately with even and odd parities
How can you express an even integer? Odd integer? Once you have expressions for each, go through each case and plug them in. After you do this, you can evaluate explicitly what the answer is.
The sum of difference of two even numbers is even, the sum or difference of two odd numbers is even. The sum or difference of one odd and one even number is even. Fit those into your formula. The crucial point is that in any case one of (n+m)/2 and (n- m+ 1)/2 is an integer and the other is a half integer.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
