The discussion revolves around calculating the flow rate of oxygen (O2) from a pressurized tank into a known volume of 25 in³. Participants explore various factors affecting the flow rate, including pressure, tubing dimensions, and the time taken to fill the cylinder.
- Exploratory
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant seeks assistance in calculating the flow rate of O2, questioning whether the Bernoulli equation is applicable.
- Another participant emphasizes the need to specify the dimensions of the path through which O2 flows.
- Details about the tubing length (35 ft) and inner diameter (1/16”) are provided, along with the pressure source (150 psi) and the filling pressure (140 psi).
- Concerns are raised about the pressure drop (10 psi) across the tubing and whether a booster pump is involved.
- Further clarification is sought regarding the flow rate specification, including whether it should be expressed in volume per second at standard atmospheric pressure.
- Participants discuss the volume of the piping compared to the volume being filled, questioning its significance in the calculations.
- Some participants suggest that the average flow rate can be calculated using the known volume, initial and final pressures, and filling time.
- There is a proposal to apply Bernoulli principles and consider Reynolds equation under the assumption of turbulent flow.
- One participant notes that simply dividing the volume by the filling time yields the average volumetric flow rate but does not account for the mass of O2 unless certain assumptions about temperature and process type are made.
Participants express differing views on the methods for calculating flow rate and the assumptions necessary for accurate results. There is no consensus on the best approach or the applicability of specific equations.
Participants highlight the importance of initial conditions, such as pressure in the piping and the presence of valves, which may affect flow calculations. The discussion also touches on the potential impact of temperature on gas behavior during the filling process.
