Fluids (finding the vel of air in a plane)
  • Thread starter Thread starter pkpiotr517
    Air Fluids Plane
To find the velocity of the air stream leaking from the window seal of an airplane cruising at 10 km, the pressure difference between the passenger compartment and the outside atmosphere must be considered. The outside pressure is 0.292 atm, while the inside pressure is 0.97 atm, creating a pressure gradient that drives the airflow. Using the ideal fluid model, Bernoulli's equation can be applied to relate the pressures and the velocity of the air. The density of air at 20°C and 1 atm is approximately 1.2 kg/m^3, which can be used in calculations. This approach allows for the determination of the air stream's velocity through the leak.
pkpiotr517
An airplane is cruising at an altitude of 10 km. The pressure outside the craft is 0.292 atm; within the passenger compartment, the pressure is 0.97 atm and the temperature is 20°C. A small leak occurs in one of the window seals in the passenger compartment. Model the air as an ideal fluid to find the speed of the stream of air flowing through the leak.
the density of air at is 1.2 kg/m^3 at 20 degrees centigrade and 1 atm.
Is there anyway to find the velocity of the air stream?
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
