Flux Linkage - what, where, why?
  • Level: Undergrad
  • Thread starter lntz
    Flux Linkage
2 replies · 16K views · last reply
lntz
Hi,
we have been doing lots of work recently on magnets. we have learned about the ideas of flux, and using them to describe induction and how transformers work etc.
i feel that i understand quite well about these ideas, but now i have come across this idea of 'flux linkage'.
i do not understand what this is. the definitions i have been reading don't seem very explicit.
so please can somebody explain to me what it is, and why the ideas are important/useful.
thanks in advance.
hi lntz! :smile:
a major difficulty in understanding magnetic flux linkage is that it has the same units as magnetic flux (Wb)
if there are N turns of wire round an area A, through which there is a magnetic field B at an angle θ,
then the magnetic flux through A is Φ = BAcosθ,
and the magnetic flux linkage through A is NΦ = NBAcosθ
the only difference is the number of turns, N, which has no units!
i find this easier to understand if we use the H field (instead of the B)
the H field is magnetic moment density, measured in amp-turns per metre (A/m)
the H flux is magnetic moment per length, measured in amp-turn-metres (Am)
eg if the magnetic field is produced by a primary solenoid with current I area A length L and turns N (and pitch n = N/L),
then H = nI amp-turns per metre (independent of A)
and H flux = nIA = NIA/L amp-turn-metres
if this flux then goes through a secondary solenoid with the same area and M turns,
the flux linkage is M times the flux, = MNIA/L amp-turn2-metres​
returning to the B field (where the concept of "turn" as a unit is unnatural :redface:):
B = µH = µnI
B flux (from the N-turn primary) = µNIA/L webers
B flux linkage (through the M-turn secondary) = µMNIA/L webers :smile:
I agree with Tiny tim reference to number of turns, N,
If you have one turn of area A in a magnetic flux density of B tesla (webers/m^2) then the flux phi = B*A webers.
If there are N turns then the effective flux is N times greater = NBA
This is called magnetic flux linkage
