Flux pinning in type 2 superconducotrs
  • Context: Undergrad
  • Thread starter Thread starter DariusP
    Flux Type
The discussion centers on the flux pinning effect in YBCO (Yttrium Barium Copper Oxide), a type-II superconductor. Participants clarify that flux pinning can occur in both bulk YBCO and thin films on substrates. The Meissner effect, characterized by the expulsion of magnetic fields, does not negate the presence of flux pinning, which is a general property of type-II superconductors. Defects such as impurities, voids, and grain boundaries in the material contribute to flux pinning, making it observable in various forms of YBCO.
  • Understanding of type-II superconductors
  • Familiarity with the Meissner effect
  • Knowledge of YBCO properties and applications
  • Basic concepts of crystal defects and their effects on material properties
  • Research the properties of YBCO and its applications in superconducting technologies
  • Learn about the mechanisms of flux pinning in type-II superconductors
  • Investigate methods for growing single-crystal YBCO using the floating zone method
  • Explore the impact of crystal defects on superconducting properties and performance
Physicists, materials scientists, and engineers interested in superconductivity, particularly those working with YBCO and its applications in advanced technologies.
DariusP
I'm wondering if for example YBCO superconductor (which is considered type-II superconductor) that exhibits flux pinning effect is a bulk or some substrate with YBCO film on top of it?
I always thought that YBCO which exhibits flux pinning is a bulk in all of demonstration videos but it struck me when someone on youtube (he was not a scientist btw, so he could very well be wrong/uneducated in this field) said that only a substrate with a thin YBCO film can exhibit flux pinning and if it was an YBCO bulk then we would get Meissner effect (complete expulsion of magnetic field lines) and no pinning.
Got me confused. Anyone know how it is for sure?
I think the guy got this whole thing backwards.
From here: http://shop.can-superconductors.com/index.php?id_product=10&controller=product
it says that
"The disk for Meissner Effect is prepared in a way that the trapped magnetic field is very weak and the Meissner Effect then dominates over the trapped field. Therefore this Y-Ba-Cu-O disk for Meissner Effect demonstration is made of polycrystalline material that shows low critical currents.
On the other hand, the disk for demonstration of strong levitation force (flywheel demo, etc.) is prepared in a way that allows flow of high critical currents and the trapped magnetic field is high and dominates over the Meissner Effect. This is achieved by preparing the Y-Ba-Cu-O disk as a single crystal of high critical currents.
"Monocrystalline means that the bulk exhibiting flux pinning is just YBCO and nothing else, right?
YBCO does exists without a substrate. One can even grow "large" single-crystal YBCO using floating zone method, and then simply cut off chunks of it. Many experiments have been done on such "chunks".
it says that
No, monocrystalline or single-crystal of ANYTHING means that the object contains only a single crystal orientation throughout the entire bulk material. A polycrystalline means that it still contains just that material, but with random crystal orientation throughout the bulk material.
Both of these show different and distinct patterns when one performs, say, x-ray diffraction experiments.
Zz.
Thanks for your reply, but what I wanted to know was if flux pinning exists in this YBCO "bulk" or only in YBCO thin films+substrate?
It can (and does) exist in either.
The large pieces of YBCO used for demonstration of the Meissner effect tend to have a LOT of defects (they are typically sintered; not single crystals) so flux pinning is fairly obvious.
However, flux pinning is a general property of type II superconductors and you get it in films as well; the pinning centres can be e.g. defects/voids in the film or even corners or constrictions in patterned films.
Could you elaborate on what exactly are these defects/voids? I'm finding these replies really helpful. A lot less confused.
The same thing as in any material. Basically anything that makes the crystal "imperfect". This could be impurities, voids (missing atoms), grain boundaries, changes in chemical composition etc
In real life there is no such thing as a perfect crystal; meaning all materials have pinning centres.
