- 30,059
- 7,373
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker.
I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test.
I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth spike into the ground with a pair of thick earth conductors connected to my system and it was 'better but my tester was not totally happy.
My new house has an underground supply and all the metal bits in the house seem to be connected by a maze of earth conductors but I can;t find any conductor going to Earth. Previous houses all had underground supplies and a strap round the armoured supply cable so I assumed I would find the same. But no. Also, if I stick my meter pointed probe into the cable cladding, I get many kΩ when I eventually make contact. How bad is that? I feel safe within the house as everything in it seems to agree about zero potential. Would a better earth reduce the likelihood of annoying RCD trips? I thought it might be the problem.
Being a bit lazy I thought that PF could give a quick, if unofficial answer. The house is 1930 build iso it will have had several generations of installations - including an array of 10 PV panels. Is it possible that the PV system could have changed the situation? It seems to be documented.
