Calculating Force Applied to Shaft from Drum Uplift
The discussion focuses on calculating the force applied to a shaft from a submerged drum when released. The drum, containing approximately 150 liters of air, displaces water, resulting in an upward force equivalent to the weight of the displaced water. To determine the net upward force, one must consider the downward force and apply the formula for gravitational force, converting kilograms to Newtons by multiplying by 9.8 N/kg. Additionally, to compute the power in kilowatts, the distance moved upwards and the time taken are essential factors.
  • Understanding of buoyancy principles and Archimedes' principle
  • Basic knowledge of force calculations (Newton's laws)
  • Familiarity with power calculations (Energy = Work/Time)
  • Ability to perform unit conversions (kg to Newtons)
  • Research buoyancy calculations and Archimedes' principle
  • Learn about force and weight calculations in physics
  • Study power calculations in mechanical systems
  • Explore practical applications of force and power in engineering
Engineers, physics students, and anyone involved in mechanical design or fluid dynamics who needs to understand the forces acting on submerged objects.
Rainierc
Hi,
I am going to try and explain this as best I can. I have a drum submerged in water (200ltr drum) filled with +- 150ltr of air. This is attached to a chain that goes around a sprocket at the bottom of the tank and the sprocket is mounted to a shaft that goes out of my tank. How do I calculate what Kilo Newton or Kilo Watt will be applied to the shaft when I release the drum to go to the surface. I know that the uplift would basically be 150kg that pulls on the chain.
Thanks Rainier
Rainierc said:
Hi,
Welcome to PF Rainerc!
Hint: the upward force is related to the weight of the water that is displaced by the drum. What is the downward force? What is the NET upward force? (I think you can neglect the weight of the air in drum to keep it simple).
PS. if your question is how to convert the gravitational force on a kg into Newtons, multiply by 9.8 (N/kg force)
AM
If you want to calculate the Power (kW) involved then you need to know something of the distance actually moved upwards and the time taken. (Time taken would be hard to work out but Energy / Work could be fairly straightforward to calculate - given the height the drum rises.
  • · Replies 24 ·
9K
