Force exerted on the pedals ?
  • Thread starter juliorgonzalez
  • Tags
    Force
In summary, the conversation involves a cyclist attempting to cycle up a 7.00° hill with a vertical height of 122 m, and calculating the work required against gravity. The average force that must be exerted on the pedals tangent to their circular path is also being discussed, with the necessary calculations and considerations being mentioned.
juliorgonzalez
force exerted on the pedals...?
-) A cyclist intends to cycle up a 7.00° hill whose vertical height is 122 m. Assuming the mass of bicycle plus person is 76.2 kg, calculate how much work must be done against gravity. I got this part by multipling the (m)(g)(d)= 91100
If each complete revolution of the pedals moves the bike 5.00 m along its path, calculate the average force that must be exerted on the pedals tangent to their circular path. Neglect work done by friction and other losses. The pedals turn in a circle of diameter 34.6 cm.
I really have no idea :confused: . so if u can help me with that
thanx
Think about it. You know the required force at the wheels,.. and 1 rev of the pedel = 5 m,.. total path is known,... divide to get the amount of force at the wheels per 1 rev of the pedels,...next use torque conversion to get force at pedals,.. remember 5 m is the outer lever distance,.. so the pedel requires more force than at the wheels
The force exerted on the pedals is directly related to the work that needs to be done against gravity. As the cyclist pedals, they are applying a force to the pedals which in turn rotates the wheels and propels the bike forward. This force is what allows the cyclist to overcome the force of gravity pulling them back down the hill.
To calculate the average force exerted on the pedals, we can use the formula F = W/d, where F is the force, W is the work, and d is the distance. In this case, the work done against gravity is 91100 J and the distance traveled for each revolution of the pedals is 5.00 m. So, the average force exerted on the pedals would be 91100 J / 5.00 m = 18220 N.
Additionally, we can calculate the force exerted on each pedal separately by dividing the total force by the number of pedals. In this case, if the bike has two pedals, the force exerted on each pedal would be 18220 N / 2 = 9110 N. This force is necessary to overcome the force of gravity and maintain a constant speed while cycling up the hill.
It's important to note that this calculation neglects any other forces that may act on the pedals, such as friction or air resistance. These forces would require additional work to be done and would increase the force needed to be exerted on the pedals.
1. What is force exerted on the pedals?
The force exerted on the pedals is the amount of energy or effort applied by a person's foot to move the pedals of a bicycle or other machine.
2. How is force exerted on the pedals measured?
The force exerted on the pedals is typically measured in Newtons (N) using a force gauge or by calculating the product of a person's weight and the force of gravity (9.8 m/s²).
3. What factors affect the force exerted on the pedals?
The force exerted on the pedals can be affected by various factors such as the weight and strength of the person pedaling, the gear ratio and resistance of the pedals, and the terrain or incline of the surface being pedaled on.
4. What is the relationship between force exerted on the pedals and speed?
The force exerted on the pedals is directly related to the speed of the bicycle or machine. The more force that is exerted on the pedals, the faster the bike will move.
5. How can force exerted on the pedals be increased?
The force exerted on the pedals can be increased by using a higher gear ratio, increasing the resistance on the pedals, or by increasing the strength and power of the person pedaling.
