Force on a metal bar across two wires in a magnetic field
The discussion centers on solving a problem involving the force on a metal bar in a magnetic field, utilizing the equations F=ma and F=-IlB. It emphasizes that the left side of the force equation should represent the vector sum of all forces acting on the bar, including both the magnetic force and any applied force. The induced electromotive force (emf) is linked to the changing magnetic flux, and there is a suggestion to consider how this emf relates to the potential difference across a capacitor. One participant prefers using the Blv law over Faraday's law for calculating emf in moving media, citing potential complications with the latter. Overall, the conversation highlights the need for clarity in the problem statement and encourages exploration of various equations.
aolivias
two parallel wires. The distance between the wires is d from each other and they are connected by a capacitor with the capacitance C. The constant magnetic field B is applied and is perpendicular to the plane of the wires. We put a metallic bar across the parallel wires and start pulling it with force F parallel to the wires. What is the acceleration of the bar?
I also attached my work to a file so it can be readable. I also did it here below:
I so far did C=Q/V,
I=dQ/dt,
I=c*dV/dt
F=ma, F=-IlB. I set these equations equal to each other:
ma=-IlB, In the next step I substituted c*dV/dt for I and got:
m*dv/dt=-(cdVlb)/dt
then, I substituted a into dv/dt and solved for a and then for final answer:
a=-(cvlb)/(mt)
I am not sure if this is correct or if I am on the right path.
I need help with the problem above
F = ma should be written as ∑F = ma. The left side is the vector sum of the forces acting on the bar.
The force Fmag = IlB is the magnitude of the magnetic force acting on the bar. But there is also the applied force, F, acting on the bar.
The current is produced by the induced emf, ε, due to the changing magnetic flux through the circuit. So, you will need to bring in Faraday's law of induction. How is ε related to the potential difference, V, across the capacitor?
The problem statement is not clear. I guess you are meant to neglect any electrical resistance in the wires and in the bar.
I agree with post 2 except when it comes to moving media I prefer the Blv law (l=distance, v=velocity) to faraday's law for finding the emf. You can get into trouble with faraday's law in moving media. The Blv law is based on the Lorentz force which has a different basis than faraday's.
Otherwise, just play with the various relations as post 2 suggests.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
