Force Relative to the vertical?
Cosine theta is vertical and sine theta is horizontal because of the angle's definition in relation to the force vector. In the example provided, theta is measured between the force vector and the vertical axis, which determines the orientation of the sine and cosine functions. If theta were defined between the force vector and the horizontal axis, the roles of sine and cosine would indeed switch. This distinction is crucial for understanding vector components in physics. Clarifying the angle's reference point helps resolve confusion about trigonometric relationships.
Scorry
Can you explain why cosine theta is vertical, and sin theta is horizontal on this example? I am confused.
Link?
Does it look like this?
https://www.cdli.ca/sampleResources/physics3204/unit01_org02_ilo03/u01-s02-ls03-lessonfig07.gif
Thanks. I attached a photo, but it's not showing up. Your example is what we're covering next, I haven't gotten there yet.
It's because of which angle theta they are using (they show theta between the force vector and the vertical axis). If they defined/chose theta to be between the force vector and the horizontal axis, that would switch the sin() and cos() terms, right?
Thanks man, it makes a little more sense. I haven't taken trig in a few years.
Likes berkeman
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 49 ·
  • · Replies 66 ·
  • · Replies 77 ·
