Force required to move a object on slope with rolling tyres
The discussion centers on calculating the force required to move a 5-kilogram object on a 30-degree slope using rolling tyres. The formula applied is F push = mgsin(theta) + coefficient of friction * mgcos(theta), resulting in a force of 25.542 Newtons. The coefficient of rolling resistance used is 0.001, though the accuracy of this value is questioned due to variations in tyre design and inflation pressure. The method of calculation is deemed correct, but the lack of a specific coefficient of rolling resistance in the problem statement raises concerns.
  • Understanding of basic physics concepts such as force, mass, and gravity.
  • Familiarity with trigonometric functions, specifically sine and cosine.
  • Knowledge of rolling resistance and its dependence on material properties.
  • Ability to apply Newton's laws of motion in practical scenarios.
  • Research the specific coefficients of rolling resistance for rubber tyres on steel surfaces.
  • Learn about the impact of tyre inflation pressure on rolling resistance.
  • Explore the mechanics of wheel/axle bearing friction in rolling systems.
  • Study advanced applications of Newton's laws in inclined plane problems.
Engineers, physics students, and anyone involved in mechanics or materials science who seeks to understand the dynamics of moving objects on inclined surfaces with rolling resistance.
adssd
Consider a object of 5 kilos which is fixed with 4 rolling tyres (like in a trolly) which is in a slanting position of 30 degree angle.
My question:How to find the force required to move the object upwards the slope along with rolling resistance considered?
I tried the force using the F push formula for slope & i tried the coeffiecient for friction of tyres as 0.001
F push= mgsin(theta) + coeff of friction*mgsin(theta)
F push=5 * 9.8 *sin(30) + 0.001 * 5*9.8 * cos(30)
F push=25.542 Newton
Is this correct?
I researched this problem in google, but since the above problem deals with Rolling friction as its attached with tyres, what is the correct method to find the exact force! I s it the correct method to find the object moving up the slope with tyres ?
You equation is correct.
is it the correct formulae to use it to my problem?
If the above is a full statement of the problem as presented to you then yes it is; however, I am surprised that you were not given a specific coefficient of rolling resistance as a part of the problem statement.
JBA said:
If the above is a full statement of the problem as presented to you then yes it is; however, I am surprised that you were not given a specific coefficient of rolling friction as a part of the problem statement.
as i am using steel surface and rubber tyres, i thought its coefficient is 0.001, but i seriously have a doubt over that coeffienct part..as the slope is steel and the tyre is rubber! is the co efficient i used here is right?
That is hard to say because the actual rolling resistance of a rubber tyre is a function of the tyre's individual design and even more importantly, its inflation pressure; as a result, to the best of my knowledge there is no one "accepted" value of rolling resistance for inflated rubber tyres.
As for steel wheels or hard rubber covered steel wheels, I have no background related to those; but, in all of these cases the ultimate rolling resistance is a factor that actually must include the mechanical wheel/axle bearing friction, etc. That is the reason, I am surprised you have not been given a specific value in your problem statement.
Ultimately, your equation provides for all possibilities, including a value of "0" so for that reason I would find it hard for anyone to question your method of calculation with no factor value given.
23K
  • · Replies 35 ·
11K
  • · Replies 36 ·
22K
  • · Replies 42 ·
  • · Replies 97 ·
