Force to stop a rotating object
  • Thread starter Thread starter Phys185Help
    Force Rotating
2 replies · 5K views
Phys185Help
The 3.2kg , 37-cm-diameter disk in the figure is spinning at 350 rpm .
How much friction force must the brake apply to the rim to bring the disk to a halt in 2.4s?
F = m * a
I = (1/2) * mass * radius2 (I probably need to use this but I can't figure out how it works in)
rotational speed = rotations/sec * circumference
I've tried going about it multiple ways, but I think I'm just leading myself in circles
Going to try to solve using F = m * a
Solving for a:
350 rpm / 60 seconds = 5.83 rotations/second
5.83 rotations / second * (2π * .37m / 2) m/rotation = 6.77 m/s
If I want to go from that to 0 m/s in 2.4s then it's (6.77m/s) / 2.4s = 2.82 m/s2
So since F = m * a = 3.2kg * 2.82 m/s2 = 9.03 N
Except that answer is wrong.
I would love to use the different rotational formulas but I can't figure out what I'm supposed to use and when to switch from radians to meters and such.
Also tried this:
Net torque = I * α
I = (.5 * 3.2kg * .185m2) = .0548 kg*m2
α = ((350rpm / 60 s) - 0) * 2π / 2.4s = 15.27 rad/s
Net torque = .0548 * 15.27 = .8363 Nm
Net torque = F * radius
.8363 = F * .185
F = 4.52 N
This one seems more correct but I've done it wrong so many times I don't know if I'm losing my mind.
Edit: Also this one is exactly 1/2 my other answer so I assume in the other one or in this one I divided/multiplied by 2 somewhere when I shouldn't have.
#2 is on the right track.
Force = mass * acceleration ... is the linear case
Torque = Moment of inertia * angular acceleration ... is the same thing but for rotation.
Phys185Help said:
Net torque = I * α
You didn't post a diagram but I assume it's a disc so I = 0.5*m*r2
Where do you get 0.185m2 ?
That should be rad/s2 because α is the angular acceleration.
