Forces, Acceleration Hard Stuff (HELP)
In summary: Px acting along the x-axis. The only force acting along the y-axis is mg*a, which is equal to Px. Therefore, the net torque acting on the center of mass is: Py*d*g - Fg*a*h.
klopez
[SOLVED] Forces, Acceleration...Hard Stuff (HELP!)
A trailer with loaded weight Fg is being pulled by a vehicle with a force P. The trailer is loaded such that its center of mass is located as shown. Neglect the force of rolling friction and let a represent the x component of the acceleration of the trailer.
(a) Find the vertical component of P in terms of the given parameters. (Use F_g for Fg, a, d, L, h, and g as appropriate in your equation.)
I have no idea on how to use come up with an expression that involves acceleration. In matter of fact I do not know where to start because this looks confusing. Can anyone give me advice?
Thanks,
Kevin
What can you deduce about the total torque about any point on the trailer?
Here is how I found the correct answer:
First, break down force P into two components: Px and Py
Second, consider the center of mass to be your axis point.
Third, derive an equation for the the net forces in y-components, [tex]\sum[/tex]Fy, and let that equal to 0.
Py + n - Fg = 0 (1)
Fourth, derive an equation for the only force in the x-component.
Px = m*a
(and since the force of gravity on the whole truck is mg, than m = Fg/g)
So...
Px = (Fg/g)*a (2)
Fifth, derive an equation for the net torques, [tex]\sum[/tex][tex]\tau[/tex] acting on the center of mass, which when summed, should equal 0.
Py*(L-d) + Px*h -n*d = 0 (3)
(Both Px and Py produce torque in the same direction so therefore they should be added and then subtracted by the normal force, which is producing torque in the opposite direction.)
Now using equation (3), rearrange the equation so that you have it in terms of n.
n = [(Px*h) + Py*(L-d)]*(1/d)
Since you know Px from equation (2), then you can plug that into the equation above.
n = [(Fg*a*h/g) + Py*(L-d)]*(1/d)
Simplified a bit further...
n = [(Fg*a*h) + Py*g*(L-d)]/(d*g)
Now using the n above, rearrange equation (1) in terms of Py, and then plug in your derived expression for n, and you have the following:
Py = Fg - [(Fg*a*h) + Py*g*(L-d)]/(d*g)
Simplify a bit so you have your Py on one side...
Py*d*g + Py*g*(L-d) = Fg*d*g - Fg*a*h
When you pull out Pyg and divide L on both sides...
Py*g = Fg*(d*g - a*h)/L
Divide g by both sides and your left with your answer...
Py = (Fg/L)*(d - a*h/g)
I hope this helps others who were stuck on this problem.
Kevin
Related to Forces, Acceleration Hard Stuff (HELP)
1. What are forces and how do they affect acceleration?
Forces are interactions between objects that can cause them to change their motion. Acceleration is the change in an object's velocity over time, and it is directly proportional to the net force acting on the object. This means that the greater the force, the greater the acceleration.
2. What is the difference between mass and weight?
Mass is a measure of the amount of matter an object contains, while weight is a measure of the force of gravity acting on an object. Mass is typically measured in kilograms, while weight is measured in newtons.
3. How do we calculate net force?
Net force is the sum of all the forces acting on an object. If the forces are acting in the same direction, we add them together. If they are acting in opposite directions, we subtract them. The resulting net force is what determines the acceleration of the object.
4. What is Newton's second law of motion?
Newton's second law states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. This can be represented by the equation F=ma, where F is the net force, m is the mass, and a is the acceleration.
5. How do forces and acceleration relate to everyday life?
Forces and acceleration are constantly at work in our everyday lives. For example, when we push a shopping cart, the force we apply causes it to accelerate. When we drive a car, the engine produces a force that accelerates the car. Understanding these concepts can help us make sense of the world around us and even engineer solutions to real-world problems.
