Why Does B(cm^3/mol) Change Sign with Temperature?
  • Thread starter Thread starter pentazoid
    Forces Molecules
pentazoid
Think about forces between molecules, and explain why we might expect B(cm^3/mol) to be negative at low temperatures but positive at high temperatures.
Well at low temperatures the motion of particles are not as high as they would be at high temperatures, so there is less kinetic energy so wouldn't they attract each other and opposite charges attractive but the product of two different charges are negative. As the temperature increases, the kinetic energy increases and attrative intermolecular forces begin to break apart and therefore a repulsive forces arises between the particles. Therefore the charges of the particle either must be both positive or both negative , therefore the product of the charges of the two particles are positive.
I think what you've said so far is fairly correct. This also ties in with the fact that attractive forces have a negative sign associated with them, and repulsive forces are positive by convention.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
