Formula for acceleration between to object.
  • Context: Undergrad
  • Thread starter Thread starter im_
    Acceleration Formula
33 replies · 5K views
TurtleMeister said:
I don't follow that. I was assuming that your scenario was for three objects, the earth, and two objects in Earth free fall. If that is the case then you need to include all three objects in the same frame. If that is not the case then can you be more specific about what your scenario is?
no, the scenario has been changed, sorry for not mentioning.
manishr said:
what i meant by that is,
let say there is another inertial frame f (beside the CoM, which is now an inertial frame).
if both objects are accelerating in same direction with respect to f,
=> there is an acceleration between CoM and f.
=> CoM cannot be inertial frame (now). because we have assumed that f is an inertial frame. so one of them has to non inertial, CoM is non inertial.
there is only two object in the space.
ManishR said:
i have no idea what you just said.
however
if there is only two point mass objects ma & mb with [tex]\vec{r_{0}}[/tex] where [tex]\hat{r_{0}}[/tex] is from ma to mb.
[tex]\frac{d^{2}}{dt^{2}}\vec{r_{a}}=-\left(\frac{m_{b}}{m_{a}+m_{b}}\right)\frac{d^{2}}{dt^{2}}\vec{r_{0}}[/tex]
where [tex]\vec{r_{a}}[/tex] is vector position of ma from an inertial frame.
Yes... And that tells you that you cannot solve the problem from accelerated frame how? Your dra/dt will be completely different, but dr/dt will be exactly the same, since it is frame-invariant.
i have never said you cannot solve problem from accelerated frame.
what i said is,
[tex]a_a = \frac{d^2r_a}{dt^2} = -\frac{F_a}{m_a} = -G\frac{m_b}{(r_a + r_b)^2}[/tex]
the step need correction if you use non inertial frame.
Ah, of course. Acceleration of a body depends on acceleration of the reference frame. But we know how to correct for that, so we can still work from accelerated reference frame.
