Fortran How can I fix issues with passing values between subroutines in FORTRAN?
The discussion revolves around a FORTRAN programming issue where a user is attempting to modify code by adding a subroutine (SUB1) to calculate a variable (QX). The user calls this subroutine within another (SUB2), which requires two additional variables sourced from a third subroutine (SUB3). The user encounters unexpected high values when printing these variables, despite not modifying them in SUB2. Suggestions from other participants emphasize the importance of sharing code for better troubleshooting and highlight that the problem may stem from variable scope, specifically whether the variables are being assigned to local variables within the subroutines. The use of INTENT(IN) is also mentioned, with an error indicating a potential misuse of dummy variables.
krishvk
Hi all,
Greetings.
This could be a basic question, and if it is, pardon me for my ignorance as I am a newbie to FORTRAN. I am trying to modify a FORTRAN code where I have added a subroutine (say SUB1) to calculate a variable, say (QX). What I did is to call this subroutine in another one (called SUB2) where all the input variables, except two, needed to calculate QX is specified / calculated. In order to get the aforementioned two variables, I called the subroutine (lets call it SUB3) dealing with them in the beginning of SUB2. When I am trying to print it out they are not passing the values I expect, but are passing very high values.
What is it that I am doing wrong here? And please note that the two variables from SUB3 are not changed in the subroutine SUB2. I tried to use INTENT(IN) for these variables; and the code in return dumped an error "Error: Symbol at (1) is not a DUMMY variable".
Any suggestion would be appreciated. Thank you for your time.
Cheers.
Technology news on Phys.org
It would help if you attach some code that doesn't work. You can probably remove all the calcs to make it shorter and easier for other people to understand.
Debugging code that you can see is sometimes hard. Debugging code that you can't see is even harder!
Hi krishvk, as AlephZero said, you really need to post some code if we are to figure this out.
I think it's quite likely however that your problem is related to variable "scope". Are you perhaps assigning these values only to "local variables" in one of the subroutines?
Thread 'Is this public key encryption?'
I've tried to intuit public key encryption but never quite managed. But this seems to wrap it up in a bow. This seems to be a very elegant way of transmitting a message publicly that only the sender and receiver can decipher. Is this how PKE works? No, it cant be. In the above case, the requester knows the target's "secret" key - because they have his ID, and therefore knows his birthdate.
11K
