Forward referencing in mathematics
  • Thread starter Thread starter V0ODO0CH1LD
    Mathematics
Forward referencing in mathematics, particularly in set definitions, raises questions about validity and potential contradictions. While programming languages often prohibit referencing an object within its own definition due to compilation issues, mathematics allows for recursive definitions under certain conditions. It is possible to define a set that references itself, but it must include at least one non-recursive alternative to avoid paradoxes, such as Russell's paradox. Careful formulation is essential to ensure clarity and avoid confusion in definitions. Overall, while forward referencing is permissible in mathematics, it requires careful handling to maintain logical consistency.
V0ODO0CH1LD
In most programming languages, mentioning an object inside it's definition can cause a lot of trouble at compile time because what's being mentioned doesn't technically exist yet.
But in mathematics is "forward referencing" allowed? Can I, for instance, define a set and use the set being defined in the definition??
For example, using set builder notation:
S = {x in X : P(x)}.
Where the formula P makes mention of S? Like,
S = {(a,b) in AxB : for all b' [((a,b) in S and (a,b') in S) => (b = b')]}.
Is that allowed in mathematics? If not, is there always a way to define things not mentioning them? In the case of the functional relation above, how would I do it?
Mathematics news on Phys.org
Unless B is either empty or a singleton your definition of S makes no sense anyway. So I would work on fixing that first before worrying about the whole "forward referencing" issue.
My second definition of S does not matter, it was just an example.. You can forget about it completely if it helps. The actual question has to do with referencing objects within their definition. I'm just wondering if that is allowed or if it raises some contradiction.
If people are careless with their writing, then it happens sometimes. In principle one should be able to avoid this however.
I don't see any reason why you can't make a valid recursive definition, in a similar way to defining a recursive function in a programming language. But you need at least one alternative in the definition that is not recursive.
But be careful - if you try to define "the set of all sets that are not members of themselves", bad stuff happens :smile:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
