Four Fundamental Forces - What Is the Fourth?
In summary, four forces are supposedly: gravity, the strong and weak nuclear forces, and the electromagnetic force. But it appears like gravity is not a force, because what we see as effects of gravity is really a warping of space due to the effects of mass on that area of space. In other words, there is really no force causing things to attract. They appear to attract due to a warping of their space but the true cause of the apparent attraction is something else. This leaves us with three forces. But then, what causes mass to have an effect on space? We think that the effect we think of as attraction is really just a redirection of an object due to the fact that the space between the two objects causes
thetexan
268
four forces?
There are four forces supposedly. But isn't gravity not a force. It appears like a force but what we see as effects of gravity is really a warping of space due to the effects of mass on that area of space. In other words, there is really no force causing things to attract. They appear to attract due to a warping of their space but the true cause of the apparent attraction is something else.
Doesnt that leave us with just three forces? But then, what causes mass to have an effect on space?
tex
I heard that we are trying to quantize ''general relativity theory''.I think that if we can quantize the space-time metric into quantum particle then it is natural to call ''gravity force'' being 4th force.Because ''force'' in QFT is the exchange boson particles process between fermions.
You are getting all tangled up in language. First, there is no reason not to call gravity a force. It acts like a force. Second, even if that were not true, your statement is "because gravity doesn't have every property of a force, it must not have any properties of a force" which does not follow.
I don't mean to make any conclusion if I seemed to do so.
There is something about mass that tends to warp space. Cause and effect. The first question is what is that something that warps space. It is probably some kind of different force (different from the first three) or it is some property of the three we don't know about. In any case there is something going on in the relationship between mass and space.
We think of gravity as a force that attracts two massive objects when, rather, we believe that the effect we think of as attraction is really just a redirection of an object due to the fact that the space between the two objects causes movement toward each other that we think of as an attraction rather than a redirection due to space warpage.
I guess the question is what is it about mass that warps space. It must be a force. There must be some kind of communication between the mass and the surrounding space. Otherwise space would not be aware of the presence of the mass. Of course, one method to warp space with no communication or force would be simple displacement...the physical presence of the mass displaces an otherwise pristine space forcing it out of shape by simply moving it out of the way. Similar to me taking my fist and pushing against and displacing a rubber membrane. What force is that? When one jumps into a pool of water and the water moves out of the way of the body, which of the four forces can that be attributed to?
tex
I think that we must content with axiom of mass warp space-time.Because we do not ''really'' understand the ontology of space-time(to nowadays).Please teach me some things if I am wrong!
Related to Four Fundamental Forces - What Is the Fourth?
1. What are the four fundamental forces?
The four fundamental forces are gravity, electromagnetism, strong nuclear force, and weak nuclear force. These forces govern the interactions between particles in the universe and are responsible for all physical phenomena.
2. What is the fourth fundamental force?
The fourth fundamental force is the strong nuclear force. It is responsible for holding the nucleus of an atom together by binding protons and neutrons together. It is the strongest force among the four fundamental forces, but it only operates at very small distances within the nucleus.
3. How does the strong nuclear force differ from the other fundamental forces?
The strong nuclear force is different from the other fundamental forces in several ways. Firstly, it is a short-range force, meaning it only operates within a very small distance. Secondly, it is the strongest force among the four, followed by electromagnetism, weak nuclear force, and gravity. Lastly, it only affects particles with a nuclear charge, such as protons and neutrons, whereas the other forces can affect all particles.
4. What is the role of the strong nuclear force in the structure of matter?
The strong nuclear force plays a crucial role in the structure of matter. Without this force, the protons in the nucleus would repel each other due to their positive charge, and the nucleus would break apart. This force is also responsible for the stability of atoms, which make up all matter in the universe.
5. Can the strong nuclear force be manipulated or harnessed?
The strong nuclear force is incredibly powerful, but it can only operate at very small distances, making it difficult to manipulate or harness. Scientists are still researching ways to harness this force for practical applications, but it is currently used in nuclear power plants to generate energy through nuclear fission reactions.
  • Quantum Physics
  • Classical Physics
  • Quantum Physics
  • Quantum Physics
  • Electromagnetism
