Fourier transform and derivation
7 replies · 2K views
arcTomato
Homework Statement: I don't know how can I derivation Eq.(2.2)
Homework Equations: Fourier coefficients
Dear all.
I don't know how can I derivation Eq.(2.2).
Where Σk is come from??
Moved from a HW section.
The derivation, which is described as capable of being "straightforwardly computed," doesn't seem at all obvious to me.
How is ##t_k## defined? I feel that more information is needed than the image you posted.
On that side note, I think words such as ”straightforwardly” or ”simply” simply do not belong in textbooks.
Thank you @Orodruin and I appreciate for your kindness.
This paper doesn’t refer to what ##t_k## is.
That’s is the point I can’t understand.
##x_k=x(t_k) = \frac{1}{N}\sum_j A_j \cos \omega_j t_k + B_j \sin \omega_j t_k## , plug the solution:
##A_j = \sum_k x_k \cos \omega_j t_k , \ \ \ B_j = \sum_k x_k \sin \omega_j t_k##, and you get:
##x_k=\frac{1}{N} \sum_j \sum_m x_m \cos \omega_j t_m \cos_j t_k + x_m \sin \omega_j t_m \sin \omega_j t_k ##, if ##m\ne k##, then the term on the RHS will vanish, since on the the LHS there are no terms of this form, so the sum over ##m## becomes ##x_k(\cos^2 \omega_j t_k + \sin^2 \omega_j t_k)=x_k##, the sum over ##j## gives you the ##N## factor that cancels with ##N## in the denominator.
That's all there is to it.
Thanks for reply @MathematicalPhysicist (I like your name:smile:).
I got it! This is the easy-to-understand explanation.
I appreciate for you all.
