Fourier Transform and Infinity Problem
frenzal_dude
Hi, I need to find the Fourier Transform of: g(t)=\frac{1}{x}e^{\frac{-\pi t^2}{x^2}}
G(f)=\int_{-\infty}^{\infty }g(t)e^{-j2\pi ft}dt<br /> \therefore <br /> G(f)=\int_{-\infty}^{\infty }\frac{1}{x}e^{\frac{-\pi t^2}{x^2}-j2\pi ft}dt
G(f)=\frac{1}{x}[\frac{x^2e^{-t(\frac{\pi t}{x^2}+j2\pi f)}}{-2\pi t-j2\pi fx^2}] (limits:t=\infty,t=-\infty)
If you sub in t=infinity or t=-infinity, both will give you 0 because t is on the denominator.
Thanks for the help in advance! :)
Check your antiderivative; you are essentially claiming that
\frac{d}{dt}\left(\frac{\rm{e}^{h(t)}}{h&#039;(t)}\right)=\rm{e}^{h(t)}
which isn't true.
Hi, I had a - insead of a + in the last exponential.
Basically to integrate the exponential, I took the derivative of the power and divided the exponential by that derivative. Isn't this the right method?
So the derivative of \frac{-\pi t^2}{x^2}-j2\pi ft=\frac{-2\pi t}{x^2}-j2\pi f=\frac{-2\pi t-j2\pi fx^2}{x^2}<br />
G(f)=\int_{-\infty}^{\infty }\frac{1}{x}e^{\frac{-\pi t^2}{x^2}-j2\pi ft}dt=\frac{1}{x}[\frac{e^{\frac{-\pi t^2}{x^2}-j2\pi ft}}{\frac{-2\pi t-j2\pi fx^2}{x^2}}=\frac{1}{x}[\frac{x^2e^{-t(\frac{\pi t}{x^2}+j2\pi f)}}{-2\pi t-j2\pi fx^2}]
No, for example, \int e^{-t^2}dt\neq-\frac{1}{2t}e^{-t^2}+C. Take the derivative of it to convince yourself:
\frac{d}{dt}\left(-\frac{1}{2t}e^{-t^2}+C\right)=\left(\frac{1}{2t^2}+1\right)e^{-t^2}
via the product rule.
In fact, there is no nice antiderivative for e^{-t^2}, or your integrand (Unlees you consider the error function to be nice). You can however integrate it over the interval (-\infty,\infty) easily by completing the square on the exponent, and using the fact that \int_{-\infty}^{\infty}e^{-x^2}dx=\int_{-\infty}^{\infty}e^{-y^2}dy, and hence
\int_{-\infty}^{\infty}e^{-x^2}dx=\left(\int_{-\infty}^{\infty}e^{-x^2}dx\int_{-\infty}^{\infty}e^{-y^2}dy\right)^{1/2}=\left(\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}e^{-(x^2+y^2)}dxdy\right)^{1/2}
Which you can integrate by switching to polar coordinates.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
